Hi all,
I bought a 1993 st1100 a few months back and was told all it needs is a carb adjustment as it would only idle. I was hoping worst case carb cleaning. Upon removing the plenum on top of the carbs one of my diaphragm pistons looked melted. I probably should have stopped there and figured what could cause this before proceeding.But instead I bought another full carb set off another 1993 for under a hundred bucks and started cleaning,rejetting and getting back on. My confusion is that the carbs look identical except my new set does not have the little fuel nipples just above the bowl on each carb and it does not look like they ever had any. I will attach specific pics. Also on carb#4 the pilot adjustment screw is on the inside of the carb as opposed to the outside on the original and on the insidepf the original is a fuel nipple. My question is which is right and what has to be done to the new carbs do they will operate correctly. Thanks any help is appreciated!
