Louie Louie
While riding today I noticed the gauge needle wasn't moving to indicate speed. It stays at 0. GPS helps, but what could possibly be wrong?
Thank You
Thank You
Thanks , is it an easy fix? Or does it require a stealer. I do have an extended warranty.@Duke: The 1100 is cable driven off the front wheel, but the 1300 is electronically pulse driven from a speed sensor on the side of the engine block.
Louie, I'm not much help, but do wonder if the odometer is still logging miles? And the dash MPG meter is still working? If yes, the speed signal is getting to the gage cluster and isn't the sensor or wiring up to the gage cluster.
Yes they appear to beAre your odometer and other distance-based functions (like the mpg readout) working ?
