I have a question: do our bikes have a rear wheel anti-skid system when downshifting? A few times it happened to me that when releasing the clutch after downshifting, I heard an unpleasant grinding noise somewhere from the drive train.
No, because the ABS can only reduce brake-fluid pressure. It can sense that the wheel is slipping and trigger the pump to attempt to reduce pressure, which might be what you're hearing, but it cannot avert downshift-induced wheel slip.I have a question: do our bikes have a rear wheel anti-skid system when downshifting? A few times it happened to me that when releasing the clutch after downshifting, I heard an unpleasant grinding noise somewhere from the drive train.
TCS kicking in would alter ignition timing, "taming" the engine, loss of power... (IIRC does the system allow ~5% slippage on rear wheel)I have a question: do our bikes have a rear wheel anti-skid system when downshifting? A few times it happened to me that when releasing the clutch after downshifting, I heard an unpleasant grinding noise somewhere from the drive train.
