Hi all
I own a 1993 ST 1100 with a bad alternator. I need to source a new 28 amp alternator or source a 40 amp and do the conversion. Any help locating the necessary parts will be greatly appreciated!
Please note, I lve in Regina, Saskatchewan, Canada but I will order the parts from wherever necessary.
Thanks
I had success ordering a 40 amp alternator off of eBay. It was a brand new Asian knock off. It was a good quality unit. I paid $145 for it. You will need an adapter plate (which is no longer available from Honda but there is a member that has made some and he retails them . Use the search feature in the upper right corner.
Unfortunately the loaner tool kit isn’t available to Us north of the 49th, no matter most of the tools needed are available. I would advise getting a new rubber boot for the drive shaft. You will need a castle nut wrench to remove the swing arm also available on eBay from Great Britain . You need the one with the arm extension so you can use a torque wrench on it. A 17mm Allen key is also required Princess Auto has them.
Becom a member of ST riders forum and that will give you access to the archives of wisdom, scroll through that for the write up on how to upgrade to 40 amp alternator. It is an excellent resource.
It will take a weekend to do, it’s mostly time consuming removing the swing arm… and there can be challenges lining up the gears on the install. It demands a bit of patience.
