ST1100 fork brace
H20SKIER
Bob
Shapleigh, Maine
97 ST1100
4867
Has anyone put one of the Motorcycle Larry fork braces on your 1100 and does it make a difference?? I'm considering one and just wanted some input. Thanks!!!!!
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
1st: if you have ABS I do not think you need one; check the size of the piece of metal under the front fender.
Don't know about MCL's if you give me a link to it I'll check it out.
I have a SuperBrace on mine and like it.
Mark
Calgary Alberta
97 ST11/06 ST13A
625
On the ST1100 non ABS it is a good idea and stiffens the front end nicely but other wise it is a waist of time in my opinion.
Bruce P
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
As long as you had your front end setup correctly when you put it on you're fine.
I had my front end setup wrong initially so when I put the brace on all I did was lock in the sticktion (sticky friction)... remember that after you put a tire on you have to loosen one set of the pinch bolts and bounce the front end up against something (while not using the brakes) to set the forks up right.
Mark
Which one did you end up getting?
This is an old thread, Mark posted that roughly 17 years ago (a day shy of 17). His last post was in October of 2023, so he is still around. You might try a PM to him... he will get an email notification. To Private Message, hover your cursor over his blue name under his avatar, click on start conversation and type away.....
BTW, MCL - motorcyclelarry is long since gone as a vendor. I'm not sure if anyone else is making fork braces for the ST1300s.
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Which one did you end up getting? I only see one for the 1300--is it the same size, or did you go with one listed for another bike?
Thanks,
Christopher
SuperBrace I searched their site and see no reference to the ST1100 any longer only the ST1300.
Mark
Thanks for the heads up SMSW!
Erdoc48
94/00/04 STs, FSC600
EDIT: Item claimed.
This may be the wrong place to add this in: A while back, I purchased via eBay a fork brace (MCL brand) that was supposed to be for the ST1100 (I wanted to place it on the 94 which never had one- my 2000 has a Superbrace branded brace)- anyway, the one I received is not usable by me (this issue is that with the ST1100 Superbrace, the underside of the brace is curved and the one I received is not, so I can’t use it on the 94 as it doesn’t clear the curvature of the fender. From some brief research, it appears on the ST1300 that the Superbrace is flat, as this brace is. I was at the point of tossing this brace that I have, but after reviewing this thread, I was wondering if anyone wants it for their ST1300. Here’s some pics:
It’s in decent shape, maybe a few minor scratches - it’ll be for free of course. I hate to throw away a useful part that may benefit someone. If you want it, PM me. Also, Joe, if you feel you want to move this to the ‘Free’ category, feel free to do so.
Washington
Mine's a '91, so I'd need the original (I'm guessing curved) version. I know it's an old thread, thanks everyone who responded. I was originally searching fork swaps to see if anyone had found inverted larger diameter forks that were a good length and load bearing to firm up the front end, and this thread popped up. If you see anything, let me know!
