Lucky
Carpe Diem
Very inexpensive GPS mount for the ST1100. This mount puts the GPS right in your line of sight.
Parts used:
Metal strap (3X7 inches) from Home Depot
RAM mount bracket for which ever GPS you have
3M Dual Lock: like super Velcro. Had some left over from my Laminar Lip but you can get it on ebay or from Radio Shack.
Spray paint (I used primer color to match the ST grey dash)
Process:
Remove the windshield.
Bend the metal strap 90 degrees upward at a height where, when you mount your GPS, it?s at a height that doesn?t obstruct the dash lights (high beam, side stand, etc).
Drill 2 holes in the metal strap to match the RAM bracket mounting holes.
Spray paint the metal strap but not on the bottom where you?re going to stick the 3M Dual Locks (cause it doesn?t attach as well to painted surfaces.
Attach the 3M Dual Lock. I used 2 strips of it.
Mount the whole thing but be sure you have it lined up like you want it before attaching the 3M to the dash area (cause it doesn?t like to come loose once your applied the taped side).
Reinstall the windshield.
Hook up some power source to your GPS. I ran a 3 foot ?mini USB to USB cable? (bought on ebay for $2) from inside my left dash pocket, out under the fairing so it came out of the upper dash area. Inside the dash pocket it?s plugged into a dual USP power port which is run back to a fuse box.
Parts used:
Process:
