- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Actually, the best way is to tilt the tube so that the fluid going down and the bubble going up do not block each other's progress.The best way of getting air bubbles removed from a tube or brake line is to make sure there are no high/low points in between.
Make sure one end is higher so the bubble will rise.
But most of the brake lines are fixed in place at certain points. It isn't possible to ensure one is higher then the other. And there are two large 'n' shaped bends in the hoses both under the headlights. You have got to flex, tap, and manipulate the tubes to encourage bubbles to move along with the flow.
But your point is well taken. The clutch and the front lever / front caliper circuits are quite easy to bleed.
