This morning I made my usual commute to work on my ST1100. It's a '97, 169,000 miles on the clock, and it's been virtually trouble free the whole time. My 35 mile ride to work was uneventful, but right at the end it sounded like it was occasionally dropping a cylinder. When I got off and examined it it sounded fine and every pipe was hot, so no obvious dropped cylinder. Forgot about it and went about my day. About five miles into my ride home the problem came back and started getting worse.
Here are the symptoms:
-Slowly lost power over the course of 5-10 minutes, getting deteriorating faster right at the end.
-It recovered briefly if I kept the throttle wide open.
-checked the plugs: dusty black, but not horrifically so. Very dry tips. Oily threads.
-I gapped the plugs, and reinstalled. No immediate difference and bike won’t start.
-Cranked the bike for a couple minutes with only hiccuping, but eventually it fires up.
-chugs like skipping a cylinder for about 15 seconds, then runs normally again.
-At this point I noticed something significant: the voltage seemed to be stuck around 7volts, even when revved up.
-back home now (thanks to friend with truck, didn't want to risk it): it starts fine and idles, but the voltage on the dashboard voltmeter doesn’t go over 7volts.
Is this the alternator? I'm assuming this bike already has the 40amp (it has tons of farkles). How should I go about replacing it? It looks like Walmart sells the same mitsubishi alternator. Will that work on this bike, or is the google lying to me?
EDIT: I know my profile says I have a 95. That one's a donor bike now, so if I can steal its alternator I will. ...I also have a 91....I think I have a problem....help?
