Gunz
Houligan
After what seemed an eternity (like two or three weeks), my loaner shock and new spring is finally being shipped (I say eternity because my old shock is shot). I bit the bullet and ordered new springs and gold valves for the front as part of the same order. Later today the bike goes in for the rear brake hose recall. I figured that I could inspect/verify the recall work (and re-bleed brake fluid) while doing the shock and spring replacement.
My question is how many days should I plan for when replacing the rear shock and rebuilding the forks? I have a three day weekend coming up, and wonder if that time frame is sufficient. I've never done forks before, though I have years experience rebuilding hydraulic valves and general wrenching. I also have the shop manual and a full mechanic shop at home, so data and tools shouldn't present any delays.
Second question, for those who've gone before me... Is there anything else to be concerned about or that I should be checking while I have everything apart? I have very little motorcycle suspension experience, and would really, really like to nail this on the first time through. Do I need to check head bearings or any of that other mystical stuff. She's got 25K miles, and I've been known to 'slightly' exceed posted speed limit and/or scrape the pegs.
Thanks for the 411,
Mark
P.S., Roger, thanks for the loaner and I'll be sending you my old unit in a couple weeks. Could not have pulled this off without your gracious help.
Thanks for the 411,
Mark
