I recently changed tires on my 2007 Non-ABS ST1300. During the procedure, I very stupidly didn't protect my left front rotor sufficiently, and tweaked the rotor carrier.... I "cold set" it as best I could, and ordered a very spendy new rotor, which hasn't arrived yet. On my first test ride, the bike felt perfectly okay, but the left front rotor and the rear rotor were !@#$%^ hot, and the right front rotor was just warm to the touch. I tweaked the carrier some more, shot some WD-40 into the arm of the SMC, and went for another ride..... I now have the front right disc just warm to the touch, the front left disc just a little hot to the touch, but the rear rotor is still too hot to hold on to.......
The rear rotor doesn't seem locked, and I can spin the wheel easily with my hand or foot. The left (tweaked and reset) rotor spins a little less easier, but also doesn't seem to bind........the bike rides perfectly, the brakes perform very well, I feel no pulsation in the lever, no squeal or other noise....
Plan:
-- when the new rotor arrives, I will install it.
-- when my service manual arrives, I will use it to clean out the SMC, and order a new assembly if I think it necessary.
-- I will then attempt to bleed the whole system.
Any advice or comments appreciated! Especially if you think my plan sucks....thanks in advance,
The world's dumbest ST1300 mechanic......
Plan:
