I wouldn't lose sleep over it. TTs fail, OEMs fail. Run it until it fails then go back to OEM.
Sent from my LG-US670 using Tapatalk 2
Don't spend money and don't dig into it (risking creating a different problem) until it doesn't stay at 3 bars in cold weather.I wouldn't lose sleep over it. TTs fail, OEMs fail. Run it until it fails then go back to OEM.
You know...my bike has a TT thermostat in it because my original oem failed and the concensus on this forum was that oems were junk, and to replace them with TT stats when you had to replace one. Now 2 years later it seems the song is being sung backwards. So I have to worry about what is in there now. Crap. No biggie for you mechanically inclined types, but it will probably cost me a couple hundred bucks at the dealer to go in here to see if I now have any issue. This sucks.
Ferret - I have to agree with NHDiesel, it's not really worth worrying about. It happens, and honestly, it's a relatively simple fix, albeit a bit time consuming. As this thread shows (I think), TT thermostat failures are rare, so if you have one, again, don't worry about it.I wouldn't lose sleep over it. TTs fail, OEMs fail. Run it until it fails then go back to OEM.
I just replaced my 2006 bike thermostat at 10,000 too. The only thing I can think of is corrosion through electric current. The wire ground on the thermostat makes me believe that they knew about the problem and tried a cheap fix and failed. You would thing they would come with a better thermostat by now to stop that problem. Would removing the wire solve the problem? No current. At least, I was able to install the quartet / accessory plug at the same time. I am getting better at removing the Tupperware. Do like the Tupperware hardware sheet!
