So I pulled the carbs to fix the coolant leak. When I reassembled, I connected the crankcase breather line to the fuel drains. Figured that out, pulled the carbs, reassembled. Throttle is hard after a 1/4 turn, catching or sticking. I checked the cable and it is good. Pulled the carbs. I cannot see anything visibly rubbing or damaged. I do not have much experience working on carbs.
Any quick thoughts of where to look, what to check and consider? I will note there is a plate mounted on the front of the throttle (for cruise control).
All comments appreciated! I have been looking on here, but the words throttle stuck do not search well!
