- Joined
- Mar 18, 2006
- Messages
- 2,835
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Removed
Sounds like there is a story here?Since posting, I had a look at the wiring and followed the low tension leads on the circuit diagram. Decided it had to be a 'spare spark' set up. Nothing else made sense really.
Thanks for the prompt confirmation. I can stop worrying about it now.
I finally got down to the right hand cam chain tensioner with home made tool, probing between the rubber guard, throttle cables and rubber tubes.
Got the bolt out without any problems, but I wonder how many aluminium washers are floating around in the Vs of ST1300 engines around the world.
+1 and look at the photos of the service manual, it takes a magnifying glass to see, but they show RI and RE for intake and exhaust, you look at the appropriate side cylinder (the photos show which cylinder to look at; right or left). Then inside the cylinder you can see the RI and RE markings as to where they should be during the compression cycle.The easiest way I found to tell that #1 is TDC on the compression stroke is to look at the lobe on the #1 exhaust cam. It should look like this
Here is a thread with some more info and a worksheet
https://www.st-owners.com/forums/showthread.php?t=72139&highlight=valve+worksheet
But, but, but he said the cams were already out.The easiest way I found to tell that #1 is TDC on the compression stroke is to look at the lobe on the #1 exhaust cam. It should look like this
