I just bought the Doran TPMS and installed it on the rubber stems to check the system and make sure everything works ok. Now that that is verified I need to install the new 90deg steel stems and sensors internal to the tire. Since I am not planning on new tires until Spring I am thinking about pulling the rubber stem and installing it myself inside. Having no experience in motorcycle tire mounting (some in car tire mounting) I wonder?
Can I break the bead and clamp or tie down the tire to get my hands in to install the 90deg stem and the sensor? Front and back?
Is there a recommended pressure to POP the tire back on to the rim?
I assume I will need at least a balance to compensate for the 90deg stem and sensor over the old rubber only stem?
Any other good thoughts?
Thanks
Scott
Thanks
Scott
