Hi All
I have always felt like a bit of a leech on here by taking everyones great info & not leaving much in return. So here goes on something I found might help you. I just installed the Audiovox cruise control & after riding I noticed on hills it wouldnt hold the speed. (plenty of goat trails here in BC to climb). So I found a few posts here where guys added check valves & some canisters which helped. As a Chrysler tech I remembered in the old days that we used a canister which came with a check valve built inside this was used for the vacuum heater controls. Dodge Part# 4677204. I was glad to see it was still available & ordered it aprox $10. It's size made it easy to install,I just put it in the vacuum line as it came out near the rear of the airbox. The wide side goes to engine vacuum. I tried it out & it works great. Makes for a nice clean install & fits the vacuum lines perfectly. Hope this helps.
