vacuum canister
Canyon, TX
2004 ST1300
5730
JC Whitney just notified me that the vacuum canister I ordered from them is now enroute. I believe this canister has a check valve already built in. Does this mean that I don't have to worry about attaching one closer to the MAP sensor (I think I've read in other posts that you should mount the valve close to this sensor)?
number9
You won't *have* to add an extra valve. The reason people added them is because they made their own canister. I guess you *could* add a 2nd one but I don't think you'd need it.
racer1735
Canyon, TX
2004 ST1300
5730
I received the vacuum canister today and am wondering if I have the right one? The JC Whitney catalog shows two vacuum canisters, one is model #810346 and the other is #810381. Both are listed for 4 cylinder enginesI received the latter. It is about 3 inches long, 2 1/4 inches wide and has three outlets on one end.
One outlet is plugged, the other two are open and are labled 'man' and 'amp'. I'll be honest in that I don't know if it has a check valve, or even what one would look like if I saw one on the canister.
Can anyone tell me if this application will work for the audiovox cc installation?
montyshaw
MonSTer
Franklin NC USA
2003 ST1300
3941
Sounds like the one I used. The 'man' has the check valve and goes towards the 'manifold' the other end goes towards the 'amplifier' or servo in the case of the cruise. I did not use any other check valve other than the one in the canister and my cruise works fine.
]Monty[
