Yes - I know the sound. I was thinking of the issues when installing the second bearing, because that does not seat on a lip in the hub. Instead, you stop driving as soon as the inner race meets up with the spacer tube. Get that wrong and one of a couple of things will happen:
- The bearing doesn't quite meet up with the tube - I mean there is a hairs breadth gap. In which case, when tightening the axle will push the centre race of the bearing the bit extra putting a side load on the bearing.
- The bearing is hammered too hard against the spacer so that the spacer tube presses out on the inner race of the already installed bearing - putting a side load on it.
It's a fine line, and can result in the bearings not running freely. I have this idea that a draw bar with thick bearing insertion tools would pull them together, and a (low) torque setting would be a good indication of when enough is enough. Take out the guesswork.
I once tried supporting the opposit bearing with another bearing driver which was resting on the work bench with the wheel on top of it. I then hammered in the top bearing knowing that it couldn't side load the bearing because both ends were supported with a full diameter, 2cm thick bearing driver. I'd be able to feel the ring when everything met up. Perfect.
But when I tightened the axle, the bearings were too tight. I haven't got a clue why that went wrong. Now when the tube gets clsoe to the inner race I feel after each tap so that I can stop the instant that the two meet. That, for some reason, works better.
Of course, the far worse scenario is if you drive in the bearing without first checking which one should go in first !
