At what mileage should I service my forks and shock? I'm thinking about 60,000 miles or if they explode whichever comes first.
You must take the forks off.Interesting.
On the forks, I reviewed the Service Manual. Do I have to take the forks off the bike in order to change the fork oil or is there a drain bolt for that procedure?
ddueling - nice video on the rebound damping. I used to race motorcycles and rebound damping, compression damping, and spring weight were very critical adjustments.
Just to be sure it is said, LOSSEN THE TOP TRIPLE TREE BOLTS before you try to remove the caps!! Leave the bottoms tight to hold the tube.+1
The first time you do the procedure it might be a LOT easier and safer to use an impact wrench to loosen the fork caps before the forks are removed from the bike. Use a torque wrench for reinstall. Honda has a guerilla installing the caps...
I agree - very important to loosen the upper clamp before trying to loosen the cap. I personally didn't have any problems getting the caps loose, and removed from the tubes.Just to be sure it is said, LOSSEN THE TOP TRIPLE TREE BOLTS before you try to remove the caps!! Leave the bottoms tight to hold the tube.
I personally wouldn't use an impact on the aluminum nuts.
Good question, does anyone have an answer. Mine is the original Showa. I have just emptied the reservoir of a small amount of who knows what and refilled with some ATF. Works a treat now.What type of service do you expect to perform on a sealed rear shock? Perhaps you mean the oil in the preload?
Raymond
