Let us know how the search goes.thank you all for the help, think i now have a clue to what to look out for, i have started with getting a new set of plugs and adding fuel treatment today, will move to next item tomorrow
i will do thatLet us know how the search goes.
somebody here who has used the fuel treatment successfully can probably give you a better idea of how long it takes to have any effect, but its going to be more than a day, unless you plan on riding a few hundred miles today.thank you all for the help, think i now have a clue to what to look out for, i have started with getting a new set of plugs and adding fuel treatment today, will move to next item tomorrow
does not explain "wet" plugs on one side, wet means richLoose / disconnected vacuum hose? Letting in too much air after the carburetor would cause a lean condition and make starting harder.
yea a got that, i know that cant be just for a daysomebody here who has used the fuel treatment successfully can probably give you a better idea of how long it takes to have any effect, but its going to be more than a day, unless you plan on riding a few hundred miles today.
It's going to take a couple of tanks, if it helps at all of course. So probably 500miles or so. Also try to put in best available fuel for a while.yea a got that, i know that cant be just for a day
It's actually the right back,My thinking is a minor leak that affects mixture with the throttles closed, once started the leak would become insignificant and then perhaps there's too much fuel with the choke on or the choke is on too long? I also forgot to ask which side showed the wet plugs. If it's the left bank it could just be because the bike leans that way on the side stand?
The observation of wet plugs and needing the choke more when cold are somewhat contradictory.
It starts with the choke on, then that particular plug gets wts regularly, that's whenever the sound isn't coming, you notice you got a wet plugMy thinking is a minor leak that affects mixture with the throttles closed, once started the leak would become insignificant and then perhaps there's too much fuel with the choke on or the choke is on too long? I also forgot to ask which side showed the wet plugs. If it's the left bank it could just be because the bike leans that way on the side stand?
vacuum fuel shutoff valve is leaking fuel into the cylinder through the vacuum line attached to #3 cylinder. Bypass the shutoff valve, clean and reinstall plug.It's actually the right back,
,vacuum fuel shutoff valve is leaking fuel into the cylinder through the vacuum line attached to #3 cylinder. Bypass the shutoff valve, clean and reinstall plug.
