Some neat things from the Yamaha info:
Suspension (Front) Fully adj. inverted 43mm fork / 190mm (7.5") travel
Adjustments include 8-way spring preload, 10-way rebound and 13-way compression damping. Front wheel travel is 190mm (7.5"). This adjustable design allows the rider to tailor suspension settings to match rider weight, load and terrain conditions.
no screwing around with changing preload spacers to make the suspension work for you..
Newly designed 270 degree crankshaft with uneven firing order (270 & 450 degrees) is used for superior traction and throttle control. This crank design and firing order reduces the "inertial torque" providing a more linear throttle response and improved rear wheel traction. The rider feels like he / she is connected directly to the rear wheel.
Hopefully no snatchy throttle, no need for a FCE, Hi pressure fuel regulator, g2 throttle tube to get smooth throttle response..
Six gallon tank...
mitch
