You can't. The side flap has to open to get to the port which prevents it from sitting in the cradle.I just don't remember if you can get to the GPS USB port when the unit it in the cradle.
yep, it says 5v 1.5AI'm pretty certain the output of the Chinavasion charger is 5V... it will state that on the labeling on the "fat cylinder", which is the voltage regulator to knock it down from battery/charge voltage to 5V.
So that cable is called Chinavasion's "charger"?
????Since you can't charge via the USB port
Good to know Phil. I have noticed that the Chinavasion version doesn't seem to be around.BTW, FodSports on eBay now sells the 5 Inch Win CE with the software for $119.
Paul - I ordered 4 and they all came as Win CE.Thanks for the info Dean.
If anyone gets the FodSports model, confirm that it's WinCE and not Android. I ordered the WinCE and got the Android.
It's doing fine Phil, if you mean that cable. Thanks.Dean - Just curious - has the charger block failed?
If not, I would leave well enough alone given the reality of water intrusion.
If it has, PM me your address and I'll send you another one.
However, remembering your experience, I messaged the seller first to be sure that was the case.
I told them if it was not, they would get them back at their expense!
I believe the CE model screen works better with gloves but Paul would have to answer that since he got (by accident) the Android model.What are the advantages of the CE based over the Android?
I’ve got two rally’s this spring, so I think I’m going to buy myself a new WinCE version as a post-Christmas present to myself.
The supplied power cord on mine got to be intermittent. The Scrambler has a USB port under the seat so I got a USB cord long enough to reach. I put the GPS into the tray and the pop open the flap and plug in. Works fine. Would be a good backup.
On eBay -Paul/Phil, do you have link for this specific version. Just in case.
