Uncle Phil
For 'extra' security ...That’s if you lost the machine screw to the clamp?
$780 delivered 2 years ago. Best money I spent on the ST1300 ... especially after fighting with 2 failed Auidovox units. The McCruise instructions are pleasantly detailed, and following them is easy if you don't rush things. I installed mine without any issues, and it has performed flawlessly. Electronic cruise control is so much more pleasant than the old vacuum-powered units.I got mine for $ 843 last year. Works great and worth every cent.
Yep, it is a good system. I don't have one on the solo as most of our long distance rides to the south or north of Europe are planned to avoid much motorway/autoroute/autobahn. But with the outfit, particularly when towing with a trailer to sidecar rallies, it is a real boon to set to 60mph/100kph (the limit in most countries for trailer towing) and not have to be constantly monitoring and balancing the speed.If you are pondering it - just do it --- you will love it.
A good decision it is! Much success on the instalation. You will be happy with the results I'm sure.Boy am I happy with my decision.
There isn’t a chance you have an LED light in the brake system, is there? If there is, a relay is needed. ( it’s one of those things that can be overlooked and not allow the unit to engage)I was unable to engage the system during its shakedown ride
As I'm not at all familiar with the CC (or any CC) could you add a little detail to how and what was swapped?Swapped the factory loom wires on the clutch switch and it works perfectly.
You ride an ST1300 ... and such quality is not being cheap. So why cheap out on the CC?I'm a cheap S.O.B.
