Uncle Phil
Prusiks? I'm not sure what they are ...
Check camping forum. Show me your camping setup, post #72Prusiks? I'm not sure what they are ...
It's a type of loop knot that acts like a slip knot. You make a loop and fold it over the ridge line, looping it twice within itself. In this application when attached to the tarp prevent the tarp from sliding to the centre, it would help keep it taught along the ridge line.Prusiks? I'm not sure what they are ...
I've already got something pretty similar to that. Thanks.It's a type of loop knot that acts like a slip knot. You make a loop and fold it over the ridge line, looping it twice within itself. In this application when attached to the tarp prevent the tarp from sliding to the centre, it would help keep it taught along the ridge line.
I use these instead
3 hole tensioner loop
I'd add 4 lines arranged as an X connecting the tips of your post...... how to get rid of the middle 'sag' which will become a rain 'bucket' when it rains -
Already tried that - couldn't get enough slack out to do any good.I'd add 4 lines arranged as an X connecting the tips of your post...
Methinks your poles need some kind of point/pin at the end you can stick through the rivets in the tarp, then attach your tie-downs on top of that and hereby tension the tarp itself...Already tried that - couldn't get enough slack out to do any good.
They already do.Methinks your poles need some kind of point/pin at the end you can stick through the rivets in the tarp, then attach your tie-downs on top of that and hereby tension the tarp itself...
(reckon similar issues while dug in during army training, using your rain-poncho as foxhole cover... wise-ass me brought some bungee rope along, which improved the setup tremendously...)
Yes. But I think the idea of a bigger tarp will solve the problem. The roof of the tarp needs to be sloped enough in oppositeSo you use two poles and put two tie-downs per pole (or 4 poles and two per pole)?
