SN exceeds the requirements of SM.
Explanation of JASO T903.
I've been using Rotella T6 5W-40 on two Suzuki's, one Honda and now a BMW that has over 106,000 miles on it. Like he wrote above, if it says it will meet the JASO certs, then it probably will. If it didn't, I think you'd have heard about it more than just in this forum. My BMW at 106K still does not use any oil between changes. It's not like it uses oil and by the time the level is down enough to add more, it is time to change it. It simply doesn't use any. And I've never had a clutch issue.I just changed my 390,010 mile ST1300 oil a couple weeks ago. Anyone care to guess what oil has been run through my bike for the last 389,000 miles?
I used to do QA certifications and I know how much of a joke you can buy with some certification dollars . I’m going to say that if the label says it will meet JASO then it probably will.
As far as new vs old formulations 60,000 miles of new formula T6 has been used in the last 2 years
And the original clutch, gears, water pump, about everything is still in the bike.
Later, I learned arguing about Rotella T6 oil years ago is futile. No offense to anyone else’s opinions. Run what you like but there is no reason to keep pointing out there is no fancy paid for cert on the bottle.
Truth be known, a lot folks here and on other forums still use T6 oil. Y’all keep on doing what your “certified” lawyer advises.
Point of reference for clarity.Shell Rotella T6 is certified for API service catagory SN
It would not be overly difficult to believe given that they have done something similar in the past with fuel additives that were harmful to fuel systems. They denied it until the law suits started.Do you really think that Shell would put that on their containers and supply the same information in writing if it wasn't true knowing they could get sued?
It is not certified API service catagory SN any more than it is certified JASO MA. API has certified it as CK-4 only.
Without hi-jacking this useful post, I will add a couple comments about the 5w40 vs the 15w40 that I have found that some of you may find interesting....
This "test" (not scientific at all) was done on at least three different times, with the same results, draw your own conclusions.
Two 2016 test bikes (New in crate bikes) were used for this test.
One bike was filled with the 5w40 T6, and the other with the 15w40 version, both ridden about 4k miles, and both placed out of service for an oil change.
The oil was drained out of both bikes completely, including the oil filters, and the drain plugs were put back in the bikes, the keys removed, and the bikes sat for 3 weeks.
At the end of 3 weeks, the drain plugs (remember the bikes had no oil in them) were removed again, and the residual oil measured.
The bike with the 15w40 weight oil drained approximately 2-3 ounces of oil, however, the bike with the 5w40 weight oil spilled oil all over the table lift, and we got about 8 ounces or more of oil out of it when the drain plug was removed.
So what does this prove? Maybe nothing, or, maybe the 5 weight fish oil drains off the top end of the motor when it returns to 5 weight oil again, and allows the engine to be started without proper lubrication?
For those folks in the camp of "the thinner oil flows faster through the engine", "I've seen the youtube videos", will say it does not matter because the oil will get back up there when the bike is started faster than the thicker oil, however, they cannot defend that the engines will not have dry start up wear and issues, unless they tear the engines down to examine them etc.
Taking this theory to the next level, on the engines that have been torn down, I've seen more wear on the engines with the lighter weight oil than the standard weight oils recommended.
I've also found that the engines with the 5w40 oil in them were almost dry upon teardown, where as the 15w40 oil engines still had oil lurking around, and the engine appeared to be well lubricated preventing start up damage etc.
These observations may mean absolutely nothing, but I just thought I'd post them here to give some folks things to consider.
Interesting, shell is at it again with their implied advertising
This add of theirs would imply that its good for motorcycles, but when you call or email shell, they will tell you that they don't recommend it for motorcycles?
I also question the API donut on the bottle lacking the Gasoline rating?
While their wording in print implies that it "meets" these things, the lack of it in the API donut MAY indicate that it was NOT tested/certified, only suggested/implied that it WOULD meet them if tested.
I would only use the 15w40 in the bike, if it were mine.
While folks have used the 5w40 for years (Goldwing folks) they HAVE CHANGED THEIR FORMULA in the past few years, and removed the gasoline rating, so it may not be the same stuff.
I have removed/replaced at least two clutches from late model ST's that started using the new 5w40 and ended up with clutch slip etc.
As far as working good so far, has anyone who made these claims, actually opened up their engines and examined them?
This is a typical example of what using the wrong type/weight of oil does to your clutch plates.
I received a PM that now leads me to believe the inquiry quoted was a little too vague, so to put a finer point on it;Zymurgy's First Law of Evolving Systems Dynamics:
Once you open a can of worms, the only way to re-can them is to use a bigger can.
Necro thread redux.
We posted a link to this thread on a vintage bike forum & opened said can. What were we thinking?
The question has been posed if oil sample(s) has been tested from the bike(s) exhibiting these clutch failures. We promised we'd ask.
Good Ridin'
slmjim & Z1BEBE
