Anybody but me have one of those Whamo-air blasters. They were great fun for knocking things off wall and emptying ash-trays when those were still being used
Stop when you accelerate and go into super high speed when you let off the gas.Anybody remember when the windshield wipers were operated by vacuum pressure instead of an electric motor?![]()
And it is?Got one in the garage.
On the '52 pattern Jeep in which I learned to drive standard shift in the Army. The 3/4 ton SMP was even more fun: no synchromesh!Anybody remember when the windshield wipers were operated by vacuum pressure instead of an electric motor?![]()
My dad had a Model T when he was in high school. He used to talk about having to back up long steep hills as it would run out of fuel if he tried to drive up going forward.My neighbor about 20 years back was old enough to remember learning to drive in a ‘27 Model T. He said it had a separate pedal for reverse and that earlier models would starve for gas on a long hill since the tank was under the seat. The cure on newer models was putting it up in the dash (gravity feed).
Sounds safe to me but then I did drive a Pinto.
Yep. Had that on my 1942 GMC one ton. You had to hit the gas pedal and the starter pedal at the same time when it was cold while also being careful not to flood it by pushing the gas pedal to much on your way to hitting the starter pedal.do any of you remember the starter button on the floor only on the right side?
You bet, and what a piece of defecation they were, rebuilt a bunch and they operated most of the time. Even rebuilt air pressure wipers off trucks that used compressed air. It was fun watching those things jerk and dance across the windshield.Anybody remember when the windshield wipers were operated by vacuum pressure instead of an electric motor?![]()
Easy one , had a couple of names , Dimmer switch or High beam switch, haven't made up my mind which is better,on the floor or up on the turn signal handle. Pros and cons ,Floor switch keeps your hands on the wheel, didn't last long before getting full of dirt and water. Turn signal switch takes a while to figure out how to use it, some never do apparently does last the life of the car though.
Scared the life out of me the first time.Anybody stand next to a semi that had a air starter?
