Article [13] ST1300 - Clutch Slave Cylinder Replacement
the CSC system on the ST1300 represents some pretty poor engineering on the part of Honda
Side bar... I noticed - working on cars from old to modern - that the the ease of maintenance is not designed into the product anymore. One example is (some of) the transverse V6 engines, where in order to replace spark plugs on the rear bank, one had to support the engine, remove engine mounts and rotate the engine clockwise to get access to the sparkplugs. Let alone the German cars where everything is hard to access since the engine bay is so densely packed to begin with.
Another example, I had to replace some crankcase breather component on my 2005 Volvo for which I had to remove the intake manifold to get access to it. It just seems like, when they design an engine, they just throw components wherever there's some space left regardless of access/maintenance.
Perfect example for the ST1300 is the alternator placed in the V of the engine (could not think of a worse place for an alternator). That location is also used by BMW (for the starter I believe??), where you'd have to take apart half of the engine to get to it.
Go figure...
I'm with ya, @draser ...I've said it before and I'll say it again:
The designers and engineers *should* be required to do simple maintenance and / or replace parts and wear items for the machines they put intoproduction.
I would guarantee we would all see more user-friendly design elements and component placement.
The fact of the matter, of all transportation consumers, we who actually do our own work are in the deep, dark minority and are never consulted for design criteria. This, and other factors, I'm sure are part of the reason so many manufacturers will not even offer service manuals to consumers.
Yeah, I'm looking at YOU, BMW. Scheisters.
When Chris and I went to Germany for the three year USAF tour, in 1976, I had to buy a car for us to get around in, until my '72 Vega came into port. I bought a '65 four door BMW from one of my co-workers.
The thing was a rust bucket, but I didn't care, I just needed it to last the two months that it would take for the Vega to get into port. But, the clutch decided it had to be replaced, so I took it to the base auto hobby shop and changed out the clutch. WHAT A PIA! After that experience I swore off BMWs of any type! :censored:
Not necessarily in my opinion. One of the biggest negative influences on fuel efficiency is weight. Manufacturers have been shrinking all of the unused space for years as part of the drive to reduce weight where possible to help meet the ever higher EPA mandates for increased MPG.
Long gone are the days of sitting with your legs in the ample space between the radiator and the engine while you worked on something.
Hi All:
OK, well, it looks like I am one of the lucky ducks who has a problem with the clutch slave cylinder (we'll refer to it as the CSC) on my 2007 ST1300.
The symptoms of a leaking or failed clutch slave cylinder are:
  • little or no resistance on the clutch lever (only if the fluid level is low - see #2);
  • fluid level in the master cylinder drops over a short time (you'll see it in the sight glass);
  • NO external leak under the bike (at least not initially - and this is important, so read-on);
  • EDIT: the clutch is OK when cold, but the lever goes soft and gears are hard to shift when it is warmed up.
If those things (especially #1 or #2 AND #3 or #4) are happening to you - it is likely that you have a clutch slave cylinder problem and you definitely need to fix it.
NOTE: the CSC layout on the ST1100 is completely different from that on the ST1300. The ST1100 CSC is mounted on the front of the engine on the clutch housing itself and so servicing it is quite simple because access is pretty good - except for working around an exhaust header on some bikes. Nonetheless, the symptoms of the problem and basic repair scheme are identical - only the access to the CSC differs between the two bikes.
The ST1300 clutch slave cylinder is mounted on the rear engine casing about 6-8 inches above the bottom of the bike (see the photo below in the article). Access to the three 6 mm bolts that fasten it to the case and to the hydraulic fittings that are mounted on it, is really tight due to the proximity of the front edge of the swing arm, the lower fuel tank, speed sensor, oil filter, gear shift linkage and a bunch of hoses, and God-only-knows what else down in there. The failure mode of the CSC is that the piston seal leaks and allows clutch fluid (which is DOT4 brake fluid) to leak into a cavity in the rear engine casing where the CSC is mounted. That cavity is reasonably large and so a fair bit of fluid can leak into it before it is filled, at which point the excess clutch fluid will dribble out of a weep-hole in the engine case casting and eventually wind up on the floor under the bike.
NOTE: it could take some time and several fillings of the clutch master cylinder for any clutch fluid to leak externally and that is why I stated that you may not see an external leak - at least initially.
Let me state for the record that I HAVE bled the clutch hydraulic system and it is all good (no air in the system), except that all of symptoms #1, #2 and #3 have occurred AFTER the bleeding operation and the fluid level continued to drop, albeit slowly, AFTER bleeding. When my CSC began leaking in the fall of 2016, I found that as long as I topped-up the fluid level in the master cylinder, the clutch worked just fine. However, city riding (i.e. lots of clutch use) caused the level to drop noticeably over a few hundred KM - and that is definitely not supposed to happen. Also, after the second time I added fluid to the master cylinder, there was a small puddle under the bike from the weep-hole in the slave cylinder - so, as noted above, the fluid eventually does go somewhere other than into the engine itself.
TEMPORARY FIXES - or - JUST SKIPPING THE CSC REPAIR ALTOGETHER
As a temporary fix, you might be tempted to plug the weep-hole with something like JB Weld - but don't.
Plugging the weep-hole is definitely not a good idea and will not keep your bike on the road any longer. The weep-hole is there to stop clutch fluid from being forced into the engine crankcase and contaminating the engine oil. If you plug the hole, you risk damaging the engine because the leak will continue with the fluid being forced into the engine. Engine coolant pumps also have weep-holes for exactly the same reason: to keep antifreeze out of the engine oil. So, while you can keep the bike going for some time by simply topping-up the clutch master cylinder as the fluid leaks out, the CSC seal will eventually really fail - and then your bike will be disabled with no clutch function (...and this will undoubtedly happen late at night, with a passenger, in the middle of nowhere, in the rain).
If you develop a CSC leak on the road, my advice is to buy a new bottle of clean DOT4 brake fluid and keep a close eye on the clutch master cylinder fluid level. Check it and top it up as necessary - and repair it as soon as possible. Don't let the fluid level drop too low or you will introduce air into the hydraulic line - and that would be a big PITA to fix on the road.
ST OWNERS REPAIR METHOD versus THE HONDA WAY....
The Honda ST1300 Service Manual provides the dealer-approved method of removing and replacing the clutch slave cylinder and at first, it doesn't sound too bad. The three main steps in the Honda-approved repair method are as follows:
1) drain clutch fluid.​
2) remove engine from frame.​
3) etc. etc. etc.​
It all sounds OK, until you get to Step 2...for which I was recently quoted the princely sum of $1273 in labour by a local Honda dealer (parts and taxes extra).
As a mechanical engineer who specializes in vehicles, I have to say that a repair scheme requiring removal of a vehicle engine to replace a small, externally-mounted $75 part held on by three small bolts, is simply stupid and is clear evidence of a lack of planning and good engineering practice on the part of the OEM. To me, this confirms that the ST1300 was designed by a team - and then simply "plopped" onto the market without any further development. You can easily see that: the first 2003 ST1300 is virtually identical to the very last over-priced 2014 models that have been sitting unsold in showrooms around the world for several years. Don't get me wrong - I love my big ST bike - but Honda Engineering abandoned this design right after they completed it in around mid-2001 as a replacement for the highly successful ST1100. With the ST1300, they created a great new bike with more power, less weight, fuel injection, better handling and some cool new features like the electric windshield and upgraded electrical system - but they did pretty crummy job on serviceability. I have seen this before in large OEMs: the Product & Development Engineering people essentially "throw the drawings over the wall" (and that is precisely the term used in industry) to the Manufacturing people, and then they just walk away chuckling.
Anyhow, being a frugal lad, I wasn't going to pay upwards of $1500 to have such a small simple component replaced and so I did a pretty extensive web search on this topic and corresponded with several people. I found in fact, that several ST Owners Forum members have done this repair without removing the engine - and you can too. It takes a few special tools (costing less than $100) and a bit of agility to get access - but the job is doable in a couple of hours and it will save you a great deal of money - like well over $1000 and possibly much more, depending on the labour rates in your locale. The other thing is that the Honda repair scheme represents a major risk of causing other damage to your bike because it basically requires tearing the entire motorcycle apart and manhandling that big ST1300 engine out of the bike. Once the engine is out of the bike, I would guess that the actual CSC repair would take about 15 minutes (really!!) - it is that simple a task.
NOTE: while a bike hoist is a great tool - I think that this is one job where a hoist will not likely help. To get access to the CSC, you need to get UNDER the middle of the bike and in my view, a hoist would make this more difficult. You will likely want a pad or a piece of thick carpet to lie on while you access the CSC from under the right hand side of the bike (see the photos below).
Anyhow, I have assembled the required parts (and courage) to take on this task but ANY assistance / advice / visits with BEvERages, etc...would be very much appreciated.
Kind regards,
Pete
ARTICLE (written on Feb. 18-2017 & revised since then):
Today (Feb. 18-2017) was a beautiful 21C (nearly 70 deg. F) and it was a big day in the Disaster Central Workshop. A friend and I replaced the clutch slave cylinder (CSC) on my 2007 ST1300. The big problem is access and how the heck to get tools on the CSC and the hydraulic fitting that is attached to it - and which tools will fit in that tight space. This is because the danged thing is mounted up on the backside of the rear engine case and is crowded with the oil filter, the gear shift linkage, a bunch of hoses and the front edge of the swing arm - and there isn't an easy way to even see what you're doing - let alone do it.
The photo below is from an eBay "for sale" posting and it shows an ST1300 rear engine case. The greenish area in the lower centre of the case with three bolt holes and large depression in the centre is where the CSC goes. The hole with the big bearing on the upper right is where the drive shaft housing attaches and way down below it at the lower right hand corner is the hole for the gear shifter shaft. The smaller hole between the shifter and the CSC is where the speed sensor mounts. The large silvery hole on the lower left is for the oil filter. You can easily see that the clutch slave cylinder mounting is pretty tangled up with everything else. I suppose Uncle Soichiro could have made the CSC harder to get at - but I think he is saving that improvement for the ST1600, which I am told is coming soon.
The next photo shows a clutch slave cylinder held in position by three small hex-head bolts on the rear engine case - with the oil filter in place to its left. The hydraulic banjo-bolt fitting has been removed from the CSC in the photo NOTE: The big splined gearbox output shaft is in the extreme upper right hand corner of the photo below.
All of the parts needed for the job are listed in the text below. I ordered them from my local Honda dealer and they were delivered within a few days. The total cost was around $95 CDN in Oct. 2016:
  • clutch slave cylinder - $75.81
  • gasket - $5.22 and,
  • the crush washers were (a ridiculous) $4.49 each - you need three of them).
Given the modest cost of a new clutch slave cylinder and the challenging nature of the repair task, I didn't even think of trying to rebuild it. Getting in there is just too difficult along with getting the old CSC out and the new one back in - to risk having a dud rebuild. Besides, the parts to rebuild a CSC are somewhere around $50-60 - so you wouldn't even save that much.
After the preliminaries of getting the lower belly fairings off, removing the brake fluid from the clutch hydraulic system with a vacuum bleeder and arranging access to the underside of the bike, the actual R&R job on the CSC only took about an hour or so.
PRELIMINARIES
Take the bike to a car-wash to hose off the underside and rear of the engine and the area around the front end of the swing arm. This will make the job much easier and more pleasant and it will reduce the risk of crud getting into the clutch hydraulic system.
Assemble all of the tools and other stuff shown in the photo below. Here is a list:
  • a garbage bag to drape the fuel tank and fairing to protect them from brake fluid spills;
  • a good bright shop light to illuminate the dark corners of the underside of the bike;
  • a new engine oil filter of your favourite brand plus half a litre of new engine oil;
  • a little bottle of typewriter correction fluid (we call it Wite-Out) to mark the position of the gear shift linkage on the splined shifter shaft that sticks out of the rear engine case;
  • an Allen key (5 mm as I recall) to remove the fairing belly panels;
  • a strap wrench to remove the oil filter (plus a little drain pan for the small amount of oil you will lose);
  • flex ring ratchet wrenches - 8, 10 and 12 mm.
NOTE: You want really good ring ratchet wrenches that are fairly long (NOT stubbies) with ratchets that have a lot of pawls so that they will work even if only moved through a few degrees of rotation ( I treated myself to some nice ones off the local Snap-On truck;
  • a 1/4" drive ratchet (also with fine rotation pawls) with a fairly long handle and an 8 mm hex socket to match;
  • a blade tool of some type to scrape off the old gasket from between the CSC and the engine case (we also used a little brass brush);
  • a little jar of Vaseline petroleum jelly (the stuff you use on baby's bums);
  • a tube of high-temp silicone grease for the socket in the CSC that engages the clutch push-rod;
  • a good JIS screwdriver to remove the clutch master cylinder lid (you do not want to strip those delicate little screws);
  • a new, unopened container of DOT4 brake fluid (this stuff soaks up water and you do not want any of that in your hydraulic system);
  • a vacuum brake bleeder tool;
  • a short (say...3-6 inch long) piece of clear 6 mm ID plastic tubing (fuel line etc.) to fit on the clutch fluid bleeder nipple;
Above: tools & supplies needed to remove and replace an ST1300 clutch slave cylinder including the 12 mm ring-ratchet wrench and the 8 and 10 mm flex ring ratchet wrenches you'll need. Be sure to buy long wrenches (not stubbies) and get ones with small rotation pawls that will still "ratchet" even if moved only through a few degrees of rotation. These are standard items from Snap-On tools.
Above: inexpensive manual vacuum brake bleeder and custom made brake fluid drain reservoir. I got the bleeder at Princess Automotive (equiv. to Harbor Fright in the US) and it worked like a charm. It is normally $70 CDN but I got it on sale for half that and it is well worth the full price IMO. Note the fluid in the Heinz ketchup bottle - that is all we got from the clutch hydraulic system.
GETTING ACCESS - STAGE 1
  • start with the bike on the centre stand;
  • drape the fuel tank & fairing area with a garbage bag to protect it from the inevitable spill of brake fluid;
  • disconnect the battery (you do NOT want a helper to hit the starter during this job);
  • remove black belly fairing panels (no other fairing panels or exhaust parts need to be removed) - requires a 5 mm Allen key;
  • remove the oil filter - you will lose about half a litre of engine oil, so you'll need a drain pan to catch the oil;
  • remove the speed sensor (I didn't do this, but Forum member Igofar suggested it and I think its a good idea for better access);
  • use the vacuum brake bleeder to drain the clutch hydraulic system (you'll be surprised at how little fluid comes out) - requires a 10 mm ring ratchet wrench for the bleeder nipple;
GETTING ACCESS - STAGE 2
  • now put the bike on the side stand - access is not great, but its OK;
NOTE: a hoist would NOT help IMHO and laying the bike right down on its left side, as several people have done, might make things easier, but we did OK on the side stand;
  • mark the position of the gearshift link on its splined shaft (SEE NOTE BELOW - added on Feb. 22) I used a little stripe of typewriter correction fluid painted across the shaft and link to mark the correct position);
  • remove the pinch bolt that secures the gear shift link to the transmission shift-shaft and remove the link itself - requires a 10 mm flex ring ratchet wrench;
  • let the gear shift linkage dangle out of the way (DO NOT disassemble the other end of the linkage that connects to the shifter pedal on the LH side of the bike - just let it dangle);
  • NOTE: now would be a good time to clean and lubricate that linkage. They are prone to seizing and that makes shifting gears nearly impossible.
  • there are 3-4 small drain hoses held within a sheet metal bale that is bolted to the rear case of the engine - slip those hoses out of the bale and lash them up out of the way (you can see the sheet metal bale in one of the photos below);
Above: accessing the CSC from the right hand side - while bike is on the sidestand. The nice warm sun made it a little more bearable.
Above: we found that working with one hand above the right hand side exhaust pipes and the other below the pipes seemed to work OK. You can see that the banjo bolt and the three (3) crush washers have been removed and are in the magnetic-bottom parts pan.
Above: access is not great - but its OK. My helper's hand is on the CSC and you can see the oil filter mounting boss, sheet metal hose bale and the gear shift linkage dangling down (note the Iron Ring - he's a Canadian engineer).
MARKING the POSITION OF THE GEAR SHIFT LINK on the SHIFTER SHAFT
This is an exploded schematic of the gearshift mechanism from an ST1100 (the ST1300 mechanism is very similar). Note the component marked "Bolt" - that is the fastener that must be completely removed.
Here are the steps to marking the splined shifter shaft:
With the bike on the side-stand: wiggle under the bike from the RIGHT HAND side and look straight up just inboard of the right hand exhaust pipes. You will see a little link with a Heim joint and a rod that goes right across the bike and connects to the gear shift pedal. That link is mounted on a splined shaft that sticks out of the rear engine case (see the photo of where that shaft is located) - this is the transmission shifter shaft. There is a 6 mm pinch bolt that secures the link to the splined shifter shaft and AFTER you mark the position of the link - you will remove that pinch bolt with a 10 mm hex socket or open end wrench. You may need to use a slot screwdriver to gently pry open the gap in the link to enable it to slide off the shifter shaft.
NOTE: the pinch bolt must be completely removed to get the link off the shaft.
It is necessary to mark the position of that link on the splined shaft so that you can put it back onto the same spline. I marked it by painting a little stripe of typewriter correction fluid (Wite-Out) across the end of the shaft and the link (sorry - I don't have a photo of that step). If you don't mark the correct position, you may reassemble the link onto the wrong spline and your gear shift pedal will be either much too high or too low. Being off even one spline tooth makes a big difference to the position of the shift pedal.
The photo below shows a view of the pinch bolt (it is the silver hex-head bolt in the middle of the first photo) on the link as you are sitting on the floor looking in just over the RH exhaust pipe. The second photo (lost for some reason) shows the linkage from below. Put a bit of Wite-Out on the link and on the end of the splined shaft to mark the correct position.
attachment.php
attachment.php
REMOVAL of the CLUTCH SLAVE CYLINDER
NOTE
: some brake fluid may drip down in the next few steps so keep a rag handy and be careful to keep it out of your eyes!
  • first loosen the banjo bolt which secures the two hydraulic fittings to the top of the CSC and pull it straight up and out - requires the 12 mm flex ring ratchet wrench;
  • remove the three (3) crush washers from between the fittings;
NOTE: one washer goes between the lower hydraulic fitting and the CSC, the second goes between the two fittings and the third goes between the banjo bolt head and the top of the upper fitting (the banjo-bolt is part no. 22 in the schematic below and the crush washers are parts no. 25 (there are 3 of them are in the assembly on top of the CSC).
DO NOT REUSE the CRUSH WASHERS (they are cheap, so buy some extras when you order your parts);
  • remove the three 6 mm hex-head bolts that secure the clutch slave cylinder to the engine case - requires the 8 mm 1/4" drive socket & ratchet;
NOTE: now some brake fluid will likely dribble out - that is the fluid that has leaked past the seal in the CSC and the reason you're having all this fun!);
  • clean the area around the CSC mounting pad and inside the cavity in the engine case - particularly the end of the clutch push rod which will be poking into the cavity;
  • be sure to remove all of the old gasket - this can be a bit laborious;
INSTALL the NEW CLUTCH SLAVE CYLINDER (Note - all of the relevant Honda part numbers are included in the text below)
  • test that the banjo bolt threads nicely into the hydraulic port in the new CSC - NOW is the time to confirm that the threads start easily (don`t ask me how I know this);
  • put the new gasket (Honda p/n 22862-MGJ-D00) on the new clutch slave cylinder (Honda p/n 22860-MCS-000);
NOTE: there are two hollow locating dowels (Honda p/n 94301-08100 - Pin Knock 8x10) in the CSC body that align the assembly with the cavity in the engine case: be sure both of them are in place before inserting the three 6 mm bolts;
  • put a small dab of high temp silicone grease into the little socket in the CSC piston - this socket engages the spherical end of the clutch push rod;
  • install the new CSC with three 6 mm bolts (Honda p/n 96001-0602200 - Bolt Flange, 6x22) - and tighten - requires the 8 mm 1/4" drive socket & ratchet;
  • put a small dab of Vaseline on a NEW crush washer (Honda p/n 90545-300-000 - Washer - Oil Bolt) and insert it between the lower of the two hydraulic fittings and the CSC and repeat for a second crush washer, placing it between the lower and upper hydraulic fittings and finally, repeat again for the third crush washer and thread that washer onto the banjo bolt - and slide the bolt down through the washer-hydraulic fitting assembly;
NOTE: this task is a heck of a lot easier to say than it is to do - but work methodically, use Vaseline to stick the washers in place, and you'll get it;
Don't worry about the Vaseline contaminating the brake fluid. You are only going to use a little bit of Vaseline and beside, you will flush it all out during the bleeding operation.
NOTE: BE SURE that the banjo bolt thread starts properly into the hydraulic port of the CSC before you start to tighten it with the wrench.
  • tighten the banjo bolt-hydraulic fitting-crush washer assembly - requires the 12 mm ring ratchet wrench (a flex version of the 12 mm may be better here);
WRAPPING UP
  • re-install the gear shift linkage- being sure to get it on the correct spline on the shifter shaft (aren't you glad you used the typewriter correction fluid to mark it?);
  • re-install the drain hoses into the sheet metal bale and be sure they are not pinched;
Now put the bike back up on the centre stand for the remainder of the job.
  • re-install the oil filter (I suggest using a new one);
  • check oil level: it will likely be at the bottom of the safe range as you will have lost about 1/2 litre when you removed the oil filter - add to correct level;
  • bleed the clutch hydraulic system (and don't spill any brake fluid on anything you care about) - requires the 10 mm ring ratchet wrench and the vacuum bleeder tool;
NOTE: the bleed nipple on the clutch hydraulic system is quite small (and fairly well hidden just aft of the coolant overflow bottle above the side stand pivot point).
I had to search around to find some clear 6 mm ID fuel line tubing to use on the clutch bleeder nipple, but once I had that - using the vacuum bleeder made the task very easy.
  • re-install the black belly fairings;
  • re-connect the battery;
  • start the bike and test the function of the clutch and observe for leaks;
That's it - you're done! :D Its now time for a tastey BEvERage, I would say.
I don't think I have forgotten anything but if I have, please point it out in a PM and I will correct the post. I wish I had more photos, but frankly, it is so tight in there that taking them wasn't really feasible.
ACKNOWLEDGEMENTS
I want to thank all the folks who have offered encouragement on this journey and most especially, to those who have given specific advice on this challenging, but totally manageable task. I also want to thank my friend Craig who helped with a lot of the under-bike fun and ST Owners Forum member MikeDo, who stopped by just as final assembly was done and got roped into helping me bleed the hydraulic system.
One final note on that task: the vacuum bleeder really was a huge help. While you can bleed the air out of a filled system in other ways, getting the fluid out of the system in the first place without a vacuum bleeder really would be a bit of a challenge.
Cheers,
Pete
What a great post. With the help of this post, I was able to get mine done. What a horrible experience. But now it’s done and it works great again.
Glad it worked out Dale - and yes, not the easiest job due to the poor access, but once you get into it, quite doable by the average amateur mechanic.
Cheers and thanks for the kind words,
Pete
Agree with Igofar and Suprasabre and another trick I have used (see the article) is to stick the fluid banjo fitting & copper crush washer “sandwich” together with some petroleum jelly (the stuff we used to use on baby’s bums when changing diapers).
It is sticky as heck so it is easy to line everything up before you try threading in that bolt - and if any gets into the brake fluid, it won’t cause any harm and will likely come out when you bleed the system.
The other key thing is: check the threads on the end of the bolt VERY carefully to make sure they are not misformed and that there is no burr that could prevent a smooth engagement of the bolt into the tapped hole.
One thing is for sure - after all the work of doing this job you do not want to strip or cross-thread that banjo bolt.
Pete
On my 2005 the slave started leaking somewhere around 59,000 miles in November of 2020. I rebuilt with OEM kit and replaced. Now at 108,000 and 4 1/2 years later the fluid is leaking again and the clutch lever had no pressure. A simple refill of the master and rocking the lever until all the air bleed out through the return hole and all works fine. (For the moment) I've ordered an OEM Slave and won't bother rebuilding this time. The rebuild only lasted 48,500 miles so hopefully the new unit will last a lot longer.
Yeah - I did my 2007 in about Feb. 2017 following its failure on a trip in Oct. 2016 - that was the subject of this article which I wrote at the time. The bike had somewhere around 100,000 km (a tad over 60,000 miles) on it, I think.
As you can clearly see in the photo in post #308 by @SupraSabre (repeated below), once the engine is out of the bike, the R&R of the slave cylinder is literally a trivial 5-minute job. However, as everyone has discovered, it isn't nearly as easy with the engine still in the bike.
...and getting that big, heavy engine-gearbox ass'y out and back in is definitely NOT a trivial task. That's why those wonderful folks at Honda Engineering specify a simple five-step process for the repair of a leaking clutch slave cylinder:
  1. drain clutch fluid system
  2. remove the engine from the motorcycle
  3. replace the clutch slave cylinder
  4. re-install the engine into the motorcycle
  5. connect, fill and bleed the clutch fluid system.
The whole thing is easy....except for steps 2 and 4 - and that is why I was quoted around $15-1800 for the repair by my friendly and helpful local stealership.
In the photo below, the slave cylinder is the little round thingy with the black cable draped over top of it. The large round threaded part with the coffee cup underneath it is the oil filter fitting and in the upper right-hand portion of the engine case, you can see the driveshaft spline. The slave is attached by three 6 mm bolts and there is a black bleeder screw on top and a boss where the banjo bolt and fluid fittings go on the left-hand side.
Getting that banjo bolt thread to start nicely is the tricky bit because you are wrestling with two fluid hoses and three copper crush washers. That's why I advocate using petroleum jelly to stick it all together while you are trying to thread-in the banjo bolt.
Aside from the cost and effort of removing and replacing the engine to repair a small device held on by three tiny bolts (what a stupid repair scheme), when I looked at the cost of an OE replacement slave (~$75 at the time) and the cost of rebuild kit which was about $60 back then, plus the hassle of getting the slave out and back into place way on the backside of the engine, I decided that rebuilding it was not worth the savings and was certainly a risky course of action given the possibility of muffing the re-build operation.
Thus, I have always recommended just splurging on a brand-new slave cylinder. Spend the $15 bucks and 1-2 hours lying on your back - and save $1500 plus the risk of allowing some pimply-faced doofus at the dealership mess up your bike.
Pete
45 minutes from start to finish (including bleeding), 1/4 inch socket set, 8mm swivel socket (not a swivel extension) a small block of wood, and knowing where the attachment points that cause binding are.
It gets much easier after you’ve done several dozen of them.
Is that corrosion in pic #4 from being parked outside all the time? that looks nasty.
Was that question directed at me?
If so, I am guessing #4 is if the inside of the clutch slave cylinder which is Inside the cover.
That nasty stuff is brake fluid turned to plant life from neglect.
It settles at the bottom of the housing, builds up, and starts canting the piston, then starts rubbing metal on metal (grey wear mark) which is why the clutch starts to fail.
Bleed them once a year if you want to prevent this.
And for what it’s worth, the shops in my area quote over $2500 dollars and a minimum of 16 hrs labor to replace one :rofl1:
Pete
I might make note, Unless you have three to four VERY STRONG guys working with you, you DO NOT remove the engine (note:1) from the frame, you lift the frame off the engine! The more you take off the frame, the lighter the frame will be!
Note 1: If you really want to remove the engine from the frame, remove the heads, remove the mounting bolts, turn the engine 90 degrees, pushed the engine to the right side.
Holy cow @SupraSabre - I like my method a lot better!
