Poor running 2003 ST 1300, can’t resolve need help
Woodstock, ON
ST 1300
Purchased a 2003 last year after quitting bikes 3 years ago with 30km and put on about 4-5k.
During that time have not been able to nail down the problem. Bike runs ruff when accelerating, does not want to rev freely or smoothly. Engine noisy under load and takes time to get up to rpm, struggling.
Brakes are fine, went over them. Clutch is fine not slipping, adjusted balance shafts with engine running, checked hoses and T splitter which is new in 2022. That year the fellow I got the bike from spent $4000.00 at shop and they went over everything since the bike has been sitting idle. They even took the swing arm off to replace clutch cyl. He damaged his left knee and quit riding 2 years ago. Bike has been owned by seniors since new and has not been abused. That’s the history I know.
This spring I striped the bike down. Bled the brakes properly, checked coils primary – secondary, crank sensor, plugs, etc. All in spec and put it back together. Did not check 02 sensors till this weekend. Left side under the seat there is a 2 pin plug “black white wires” where I get no reading. On the right side similar plug reads around .4-5 ohms. Have not been able to find 02 sensor related problems on the site so asking for guidance. From what I understand that plug supplies 12V to speed up heating of sensor during cold starts for emission reasons. Don’t know exactly where the 4 pin plug for the sensor is located to check the other 2 wires. Correct me if I’m misunderstanding how the sensor works. I also notice at the end of handlebar a very slight what seems like a misfire which was confirmed by a friend of mine the morning. Would a bad 02 sensor cause all the problems. Rode gmtech94’s 2004 bike last year for comparison and what a difference. Smooth, pulls strong and feels like a different animal.
Image of plug. When I puled the wire from underneath the frame rail there was a note wrapped reading “preventing measure” that I assume was placed by the shop that worked on it last.Plug.jpg
I’ve hit a dead wall with this bike and could use all the help I can get.
I would start with checking that each cylinder is getting spark and fuel. Have you pulled all the plugs? Post pictures of each one, and note which cylinder they came from.
Is the FI indicator blinking at all? If so note the code that it's displaying.
I would also check the air cleaner and housing to make sure a squirrel or something didn't turn it into a living room.
O2 should not cause a running issue, if the ecm doesn't see a signal it should go to a default setting. While idling pull the plug wires off one at a time and make sure each cylinder is firing. Lack of power sounds like a dead cylinder to me.
Pull each spark plug cap off clip the plug wires back and screw the caps back on the wires. Could also be a bad plug cap. If the spark plugs were changed check and make sure you did not install counterfeit spark plugs. This has been a big problem lately.
Check that your spark plugs leads are routed correctly. I once saw an ST1300 with the #1 and #3 leads backwards and it actually ran pretty good.
Also maybe run it with out the mufflers, maybe one of the cats burned up from a misfire and exhaust can't get through. Good luck.
Has the compression been checked?
Had the plugs out several times and all seem to be burning the same. They are original NGK.
Fuel pump is working fine and was out in 2022. I’m pretty sure its not the problem. Not many miles since it was gone over.
New air filter last year, there were mice in there. Had it of recently and its perfectly clean in there.
Checked underneath for any problems with wiring and hoses throttle bodies, ail fine. I did not pull the injectors out to clean them thinking a lot of riding might do the job if they were partially clogged. Maybe I should of done it while in there.
Plug wires are in order and are marked so as not to mix them up. Swapped 1 and 3 just to see how it ran and it ran bad. I did try pulling one at time on 1 and 3 and again ran badly. Have not had the plug caps off so will try, but when I tested the coils through the plug wire it read properly.
Did compression test last year and all 4 were fairly even. There are no lights, codes other than the fuel light at startup for a few seconds.Plugs1-3.jpgPlugs2-4.jpgThrotleBody.jpg
Did you replace the fuel pump with new or just clean the filter. I had the same issue with my ST1300 and it was the fuel pump going bad once heated up a bit. Checked good on the bench.
So did you pull the spark plug wires on 2 & 4 ? What's the fuel pressure? If you don't know that how do you know the pump is good? Also it sounds as if this bike never ran properly from the day you bought it, correct?
Removed the plugs and all look like they are burning the same. Gap is correct, -.035.
Removed all the plug caps and tested. On all 4 they read 5.9 to 6.8 ohms.
Spark cable wires look fine, nice clean copper.
Runs badly if any one cable is pulled of the plugs.
Have not removed fuel pump. It was out in 2022 when the bike was gone over.
Does not feel like fuel starvation but rather like back pressure. Have had a few bikes over the years where there were pump issues but this one does not show same symptoms.
Last Sunday morning I rode 20 mile flat stretch at around 4500rpm with not a hiccup. No sputter or anything like it but not ruling out pump issues.
Yes the bike never ran right from when I bout it. I took it around the block and was very light on the throttle. Was afraid of dropping it, “I’m old and weak” so never got past third gear, maybe 3500rpm. Seemed fine since I was not familiar with the ST 1300 and fount the throttle to be very snappy. Also there is a noise like a gear was cut out of round, wooo wooo wooo which makes me think there is a issue in the drive line as well. Later when I went out on the road and tried to get the rmp up the problem sure got me worried. Spoke to several knowledgeable people including a bike mechanic friend and they suggested to just ride it as the problem might be the fuel injectors which will clean out with additives and riding it.
At startup the bike idles smoothly around 2000rpm for a bit and I get strong gasoline smell, unburned fuel. It has been a concern of mine which lead me to think of the 02 sensor.
That is as far as I got since I work slower each year.
Anything else I should look at, would appreciate suggestions.
There is the possibility that when the previous bike shop repairs were done $4000 worth, the removed the cams to shim the valves as regular service requires. Might of got the timing marks off a tooth. The wooo woo sound may be the cam chain out of adjustment. As far as fuel injectors being bad pulling off the plug wires 1 by 1 indicates all the cylinders are firing therefore the injectors are firing......Fuel injectors need 50psi to work properly. Without a code present it's hard to speculate what's wrong. I would say that if there is no code for a O2 that's not an issue. An open O2 would certainly throw a code rather quickly. If you think there is too much back pressure remove the mufflers, the cat converters are on the mufflers and could be melted but
I have not heard of any yet.
CAMSHAFTS-CHAINS, My worst fear
Have thought about the cams for a long time since the engine is just not breathing right and compression fairly even but lover than what it should be.
My assumption was the shop would of checked the cam timing several times before the buttoned up the engine.
In 1969 I worked in a bike shop in Vancouver and have never taken a bike to a shop since. Not to say that all shops are bad but unfortunately time is what matters and things get overlooked.
Looks like I’m going into the bike again which I should of done in the spring. Have no workshop manual but there should be enough info on the site to check cam sprocket alignment. Will take me a while, work 10 times slower than than I used to.
Will update once I have a good look inside.
Thanks AL st1100
I hope you're not experiencing the bad-SMC brake drag.
Not a brake issue. Went over the brakes last year and again this spring when bike was apart. Brakes are fine.
I'm into the cams right now and from what I see all is fine. One exhaust valve is at bottom limit but a .009 filer goes through smoothly, figure about .0095.
Cam sprockets line up properly and am now at a loss as to where else to look for my problems.
I may have missed it but have you done a throttle body sync?
Have not done a throttle body sync but I did check with a small dia new drill and the throttle locked. I know its not the way to do it but it gave me a close reading and no noticeable difference in the butterflies. Will have to do it properly with a vacuum gage.
The valves, cams all checked out fine with the alignments and shims spot on. Was quick to judge whoever was in there before, they did a good job. Removed and checked the coils and cables cleaned any possibility of bad contact and still get a slight what seems like a misfire when idling. Have not found any images of the plug cable routing which I don’t know if correct so if anyone has a image please post. The only thing I found problematic was my age.
What I did notice is that someone has been into the clutch. Spotted the small bolts on the cover had been wrenched on. Don t understand why anyone would be into the clutch on such a low km bike. There is a definite wooo, woo sound neat that area. Hart to tell if from engine or drive train. Les so pronounced when clutch pulled in which I think is normal.
Went for a 70km test ride to Stratford early this morning to check for any leaks and such. All good.
Check the sparking system. I had an article on this which seems to have been lost. I’ll see if I can locate it on my computer and add it back.
The ignition coils rely on a good frame ground. There is an earth strip that can corrode that makes contact with the frame round the back. Take the coil off, clean it up.
The HT leads are a push fit onto a deep seated spike one you have undone the thumb screw nut. Make sure that the copper leads have not turned to green verdigris.
The resistance of the spark plug cap should be 5k ohms. You can measure it with the HT cable attached.
The plug cap is a screw fit onto the HT cable that connection could be corroded inside. Put a mark on the HT leads where the cap and cable meet. Check the core for verdigris. Check the cap resistance again without cable attached. Screw the cap back on.
You can use ordinary copper cored Ht leads, but if you do, you have to find a way to put a gland on the at the coil end so that the thumb screw can push the gland and cable onto the spike and hold it there firmly. I have not found a suitable non-Honda replacement for the Honda plug cap.
If this is the issue - in my experience it results in unreliable power, almost stalling when setting off, Rough running and requires high revs to keep the engine pulling.
