Ignition Switch issue
ireland
honda st1100
Hi anyone have the Issue with Ignition switch started getting it before bike parked up past 24 mnts , but worse now , on Getting everything back together had to keep key turned back slightly left to start bike had to keep held in left posture say 11pm position to get lights up & start , What's the easiest quickest fix first please! Bike did Fire up just added bit of Redex 2.5 ml per litre fuel so added 12.mm total didn't even try didn't drain carbs before parked maybe got lucky as wasn't planning on it being in shed unfinished that long!
ok thanks no harm might only work temporarily was hoping on more insight on the Actual issue & Long Term Solution fix. but appreciate your input Phil 🕵️
