Information About Riding A Honda NC750X
I am inquiring about renting a NC750X if I go to the Pan Clan Gathering in 2027 in Scotland.
It appears the battery is behind a panel in the frunk.
How hard to run wires out of there for something like heated gear connection and a GPS connection?
For those of you who own one and used to own a ST1100 or a ST1300 - anything to be aware of?
How do they compare on the road and in the twisties?
This will be a manual one since they do not have one with DCT.
Infor based on experience will be greatly appreciated.
I put 110,000 miles on my ST 1300 before selling it. I have put a little over 82,000 miles on my 2 NC 750s, but they are both DCTs. They are incredibly capable motorcycles. Yes the battery is behind a panel in the frunk. There are 5 push pins to remove the panel. (I'll put up some pics in a bit) The battery is held in by a rubber strap that's a little tough to get on and off. However, you can get to the battery bolts without removing the battery.
I consider my NCs great solo State Highway touring bikes, just ok freeway touring bikes. 45-60 mph roads suit it best imo. 80 mph freeways can be done but you're talking about a 58 crank hp twin that has a top speed in the low 90s which doesn't leave a lot of power for freeway passing. It weighs right at 500 pounds. Very easy to manage, handles quite well with decent tires ( I run Michelin road 5's on mine). I average about 74 mpg. Generally, fill up the 3.8 gallon tank under the passenger seat at 160-180 miles, but just went 253 miles on a tank the other day, using almost all of the 7/10 gallon of reserve.
I love my NC 750s, and can't imagine owning anything else at this stage of my riding career.
Both dduelin and Donk are also both former ST 1300 owners who also have or had NC 750s.
Angry Bird and Blue Bird my 21 & 23 NC 750X DCTs. (I have 76,000 mi on AB and 6,000 miles on BB.)
BB at OH-SToc this year
AB at OH-SToc last year
Is there an easy way to get auxiliary power wires from the battery out of the frunk to external devices?
Does the inside of the frunk get very hot while riding?
Since I probably weigh 100 more pounds than you, or Dave or Donk, I wonder how well it would haul my carcass?
Phil I've heard the frunk can get warm, but I've never felt it.
The lid to the battery is a little flexible plus you can leave a couple of the push pins out at the top of the cover and have plenty of room. In theory you could actually leave the cover off. Battery isn't going anywhere. I drilled holes in my lid for my battery tender jr and Noco jumper cables (Necessary because mines a DCT and can't be bump started if battery goes down) Ther frunk lid still closes easily with the black wire for my Tender jr /heated gear pinched in it. I don't think it would close with the thicker(red black) Noco cables sticking out of it though.
My nephew (the guy in white) also rides an NC 750 DCT and he makes you look like Olive Oil
He's in purple in this pic
Here's my NC700X at the top of Crabtree Mountain during the 2012 BRG. That was a 2012 manual transmission, I now ride a 2013 DCT. I've ridden NC700s as a second bike in the stable like ferret with 100,000 miles the next milestone on NC700Xs..
The original 700s had 51 hp, the 750 models 58 hp and the 2021+ frunk was redesigned to move the battery to the rear of the compartment instead of at the front of the frunk as was the case with 2012-2020 models. The frunk is not sealed off and you can run wires out of the battery access opening by leaving one or two of the panel fasteners off or run the wires out the side of the battery compartment down then along the frame to the front of the bike.
The parallel twin NC has roughly half the hp of a 1100 but 225 lbs less. It will probably feel underpowered and vibratory compared to the Honda V4 but will easily earn a ticketed performance award in any jurisdiction but Bonneville. It is very nimble and handles very well but hp is hp. I had no trouble at the 2012 BRP running the pace of those rides but I weighed 150 lbs.IMG_0614.JPG
My '21 was a six speed and a really good bike. It's a blast to ride in the twisties. No matter what the Ferret says 4000rpm is the sweet spot for performance. In '21 Honda changed the ratios in the gearbox making the first 3 gears lower and the top 3 gears higher making it an excellent tranny for the bike. The bike does everything well and I expect you'll enjoy it.
Now that is an amazing statement! How fast is 4K in mph?
4K on my DCT in STD mode in 6th gear is 80 mph. Expressway speed limit here is 65, 70 a little north and south of me. I'm a speed limit +-5 kinda guy. I'll run 72 in the 65 one and 75 in the 70 zone, but then again I don't go on the freeway much, but usually am riding in the 45-55 mph back roads where I will run 45-60. I'm mostly in the 2500-3500 rpm range,. My bike in std mode upshifts shifts at about 3200 rpms.
My 1100 runs 70-75 MPH in 5th (top gear) pulling ~40-45 MPG.
Have any of your bikes ever hit the rev-limiter?
What's the highest RPM they've seen?
I have never hit the rev limiter, even during aggressive overtakes. Is it possible the DCT has different gearing than the standard transmission? Seems I was showing higher revs at 80mph?
I've got a '21 DCT and used to own a '10 1300. The NC750 is clearly not in the same category as the 1300 - or your 1100's, Phil. I have some issues with the DCT that are easily solved with the paddle shifting on the left handlebar - but you won't have these with a clutch and shifter. In some situations, I've found the power (read acceleration) wanting - when on my 1300 I had no compunctions at all about passing a car - just roll 'er on and the bike went. On the NC I think twice and three times about the same thing, and often stay behind the car doing a few mph under the speed limit. I don't like this bike on the freeway - too many loose nuts behind the wheels in huge SUV's and the NC simply does not have the oomph to zip away from them.
I've nowhere near the mileage on my bikes that Mickey and Dave have, but I don't particularly like the 270º crank and its muted vibration. I loved the smoothness of my 1300, and then the characteristics of my VStrom 650. Puttering along on 2 lane highways on my NC is nowhere painful due to vibration, but it is a nagging bother (and nothing more). I put in the Cogent Dynamics cartridge emulators in my front forks, and still find the suspension a bit harsh over the asphalt expansion bumps we have on many roads around here. I need to adjust the air/preload but I've been lazy. I think the bike will feel vastly different for you, Phil due to your weight.
As mentioned, wires can be led from the battery down and then along the frame under the side fairing piece. In fact, this side fairing just below the tank, just pops off with plastic 'stabs' that fit into rubber grommets. The rear part of the fairing sits under the pillion seat so don't try to remove the whole piece.
Seating, for you, who is used to custom RDL's on all his bikes will be another story. Phil, you are nowhere near my size nor that of Dave or Mickey. The guys who like this bike all seem to be, ahhhhh altitude challenged. At the very least, you should head to a local Honda dealer and throw a leg over this bike. I think you might feel it is a bit cramped. I also worry that your shoulders might not like the handlebar position. Maybe bring along a sheepskin seat cover to see if that makes the somewhat controversial seat more comfortable. I read a guy circumnavigated Australia on a 50cc bike. That proves any bike will do for some people and the machinery will outlast most humans. However, Phil, you are no longer a whippersnapper, and your body might complain enough on this bike to mar an otherwise splendid vacation.
The bike handles well in the twisites, it feels planted and more capable than I as a rider. I don't think this will be an issue for you, since, IIRC you are not an aggressive rider. More important is how the bike will handle with your weight aboard, since I think it was set up at the factory for a 150ish lb rider. I cannot answer this - maybe find a member w/ an NC near you and take it for a spin?
I'll add that the NC700/750 motorcycle was the best selling Honda in Europe for several years after the 2012 debut and still is the 5th best selling Honda model in the UK. I can't believe most riders across the pond are 150 lb and 5' 6" tall. Still would be a good idea to try on on for size. Maybe a dealer in or near Knoxville has one in inventory.
I put a fair amount of highway miles on mine and it was never a worry. WI to MA sure without a second thought. Never found a situation when I couldn't zip away from a bothersome car. The seating position is near ideal too but that is subjective. Honestly a bike that performs beyond its spec sheet.
