Warm & Safe glove liners
Mophead
Texas panhandle
FJR1300
Anyone have experience with Warm & Safe electric glove liners? Looking for some heated gloves and saw these heated glove liners and thought that might work if they are thin enough to go into gloves without bunching up.
I have the Warm & Safe heated shirt and long johns and love them. Shirt works so much better than jacket liner so thinking the heated glove liners might be worth a look.
I wouldn't mess with that solution - heated gloves are better... I had some heated socks thinking they would be great and they were.... until they shorted out and put a burn blister on my foot.... I don't think anything that thin with wires are going to have much reliability.
My experience with W&S Gloves - they kept dying at around 12 months from wire breakage because I used them a lot.
Once I was on a long trip and it put me a really tough situation.
When my hands get cold, they cease to function which is not a good thing on a motorcycle.
Because they considered it a result of 'normal wear and tear' they fussed about replacing them.
And yes I communicated directly with the owner. ;)
I took a pair of the gloves apart after I gave up on them and saw why.
The wire used in the gloves (and probably the liners) is so thin that if you slightly touch it with a soldering iron on low, it melts.
Not saying other folks experienced that, but I did - 3 times.
I ride year round (commuting back and forth to work) and wore them a lot.
After Gordons (which I really loved) went belly up , I went to California Heat Gloves.
They are holding up fine (supposedly they use more robust wire) and put out a lot of heat.
Not W&S gloves, but liners on Amazon that are made with graphene heating elements. Supposedly they heat more efficiently and evenly than other gloves and are thinner. Here's the link to the ones I bought.
I looked at some others, tried them at home and settled on these. All worked well and all had great customer reviews. I went with these even though they were a bit pricier solely because of the thickness. I have a better chance of being able to comfortably wear these under other gloves. Ironically, the main gloves I plan to wear them with are my old Gerbing gloves. I agree with @Mellow that actual gloves are a better solution, but I could spend a lot of money chasing down why the old gloves didn't warm up enough.
If I'm not mistaken, graphene heating elements tend to be larger than a wire - more like a piece of fabric that heats all over. Years ago when I bought my W&S heated jacket I had a conversation w/ the owner. He bragged how they pioneered the use of very fine, flexible heating elements that were copied by everyone else.
I haven't tried the WNS glove liners, but I do like their gloves after my 20+ year-old Widder gloves gave up. The WNS are on their fourth season.
Don't jinx me!!!
(To be fair, it was all the other wires connected to the Widder vest that ultimately couldn't be repaired any more.)
The problem with liners, for me, is apparently I have very large hands and I find it difficult to buy gloves that are large enough, so adding anything, however thin, would actually make my hands colder because they would be constricted inside my gloves.
I have several pair of XL gloves of various brands, and they are barely large enough.
I have one pair that is XXL, that is almost perfect, but they are basically summer gloves.
And I'm only a buck-fifty, and 6ft tall.
Go figure.
Which work decently in jackets - in gloves, not so much with a lot of flexing and use.
Yup. And because of that they spread the heat over a larger area and you don't need the added insulation you need with carbon wire. More insulation seems good...and if that's what you want, great. But that also means they are thicker and your old gloves may not fit over them.
I tried three different gloves. I saw some great gloves for $59. They were just a wee bit thicker and I decided it was worth it to get the thinner ones. Even the thickest gloves were great. It was a hard choice to make. If you're interested, I'll post links so you can look over them yourself.
The thing to consider is that liners make the “feel” very thick. When you stop you have to take two gloves off each hand to reach for a wallet etc.
Your favourite gloves become too small with the liners and bigger gloves will be awkward.
I have both warm and safe gloves and liners and prefer the gloves. I’ve had mine for over 10 seasons with no problems so far. They aren’t waterproof but even when wet they kept my hands warm.
+1. My hands get bone cold very easily. Now with occasional arthritis and trigger fingers (2) in one hand, heated something is a must. I was gift a pair of H-D heated gloves that plugged into my W&S jacket liner but on a separate channel. They are amazing. The block a lot of cold that other gloves I've owned didn't. Then a turn of a knob and my hands are toasty warm.
I thought about glove liners but the idea of wearing (as Unc said) two pairs of gloves was just untenable. Given the experience of heated liners shown in this thread — I'm good with gloves.
Forget about glove liners and just send your gloves to Ken Phenix to be wired. He comes highly recommended, and when my current gloves die I'll take advantage of his service. For some reason I can't post the link, but you can just search "Ken Phenix Flaming Hot Motorcycle Gear".....he's on Facebook.
I did email Ken when Gordons closed up shop to see if he could put heat in the Churchhill gloves that Gordons used.
But for me, when I compared the price of the gloves I wanted plus the price of added heat, I ended up going with California Heat because of the sizeable price difference.
But if you have winter gloves you really like and already have, it is great option.
Yup, I get it, definitely higher price for a premium product. He uses flexible sealed carbon fiber heating loops that can handle the continuous flexing better than a wired setup. I'm hoping it's a buy once cry once. I've had my heated gear fail on me a few times.....not fun, lol.
IIRC, the California Heat company uses the same stuff or something similiar.
https://www.california-heat.com/pro...KVO1TQlSm3Q84-c_mblbjQyPqlCPAvpEf5V8D_npBqx4J
Lifetime Warranty on the Finewire™ Heating Elements & Plugs
Finewire™ heating elements are composed of interwoven, highly conductive microfibers that have a heavy-duty coating applied. This superior craftsmanship creates an extremely durable product that heats up quickly, ensuring comfortable warmth during any cold weather activity.
But as I've learned from Gerbing and Gordons, 'Lifetime Warranty' is only good as long as the company is around. ;)
Maybe similar but not the same. The carbon fiber loops Ken uses has better fatigue resistance and does better in moist environments than interwoven microfibers.
When I was commuting, I had bought TourMaster Liner and gloves. After a number of years the wiring would break, so I rewired them.
And a few years before retiring I had bought all new. The last time I used them was my January 2022 trip through the Nevada desert to Sacramento. I was sure glad I had them for that trip!
