After buying this fairly expensive bike, and riding it alone for a while, I took SWMBO for a ride. She was not too pleased at all with the abruptness of the throttle response, and the "herky-jerky" way it felt to her compared to the BMW Airheads we HAD been riding up 'til then. I tried explaining that not only did I need to get used to the bike more, but it was fuel injected, etc, which made not a bit of difference to my regular pillion rider. She wanted smooth.Not PRETTY smooth...she wanted smooth. I did my homework..Ivan's FCE seemed to be the most efficacious mod/farkle to do, so I called up Ivan's and ordered one. It came, and in a few days, I installed it. Easy job, much easier than I imagined from the descriptions I had seen.
Did it work? Wellllllllllll..yes..and no. It did improve the overall "feel" of the bike, it did eliminate some of the jerkiness, but well..I found it a bit disappointing. It did nothing for the heat problem, which Ivan's website claimed it would alleviate.
Next, I investigated the G2 Throttle Tamer ..the vast majority of folks seemed to think this was a good mod, and most (but not all) felt that it improved the ride-ability of the bike considerably.I figured this was my next mod.
In reading about the various questions and comments, I came upon one member who brought up a good point-why not modify the stock throttle tube to match the profile of the throttle tamer? Thanks to Vitaliy, I i took a look at this, and decided to try it. I figured at the worst, if it failed, I could repair it with plastic epoxy or JB weld, and order a new one.
I removed it, and cut a groove corresponding to the top cable, using an end cutter mounted in my drill press. The picture shows the groove after I cut it, but before I filed it smooth, and sanded it. I decided to keep the groove small to ensure the integrity of the plastic piece, and to see if there was any change at all.
I re-assembled, and went for a ride...YES..big difference, mainly in taking off, and around the twisties- no more JERK when trying to roll back on the throttle. I rode around the back roads for a while, then went to pick up SWMBO at work, to take her for a 20 minute ride and show off my handiwork. She was impressed, and could tell the difference.
I really don't see any downside, but will re-post as I ride it longer.I'll try to post a picture of the rough cut on the tube.
