+1 on what Ralph said. You shouldn't have any problem with the 91s' crankcase breather system. The water pump will have to be replaced if it starts leaking. Some folks replace their water pumps at the same time as the first timing belt R&R, at around 90K per the manual; but, most would wait until the second timing belt along with the tensioner and idle pulleys (me included). Here's a file of some research I did a while back to confirm the part differences:
~~~~~~~~~~~~~ Crankcase breather info-PNs.txt ~~~~~~~~~~~~~
1991 Honda ST1100 Crankcase Breather System:
[using the remote desktop fiches accessed through Service Honda:
http://www.servicehonda.com/test/index.htm
Aug '08]
--FUEL TANK fiche --
17551-MT3-000 / TANK, BREATHER [plus 3 hoses and their clips]
17358-MT3-000 / TUBE [air cleaner hose]
95002-02130 / CLIP, TUBE (B12.5) [air cleaner hose]
95002-41250-08 / CLIP, TUBE (D12.5) [air cleaner hose]
17359-MT3-000 / TUBE [gearshift linkage cover hose]
19505-KS6-700 / CLAMP, WATER HOSE [2 ea - gearshift linkage cover hose]
17357-MT3-000 / TUBE [transmission case hose]
90682-SB0-671 / CLAMP, CANISTER HOSE [ 2 ea - transmission case hose]
[92-02std&abs: Only the 91 has an external crankcase breather chamber. All other years/models have theirs internal to the crankcase and vent to the airbox via a port/nipple on the water pump housing]
-- SHIFT COVER fiche --
11350-MT3-000 / COVER, SHIFT
[92-02std&abs: 11350-MY3-000 / COVER, SHIFT]
-- REAR CASE fiche --
21110-MT3-000 / CASE, RR.
[92-02std&abs: 21110-MY3-000 / CASE, RR.]
-- WATER PUMP fiche --
19200-MT3-000 / WATER PUMP
[92-94std&abs: 19200-MY3-010 / WATER PUMP plus breather hose and clips]
[95-02std&abs: 19200-MAJ-G20 / WATER PUMP plus breather hose and clips]
[92-02std&abs: 11150-MY3-010 / HOSE, BREATHER]
[92-02std&abs: 90646-657-000 / CLIP (16MM)]
[92-02std&abs: 95002-02130 / CLIP, TUBE (B12.5)]
-- CRANKCASE fiche --
11000-MT3-000 / CRANKCASE SET
[92-94std&abs: 11000-MY3-010 / CRANKCASE SET (replaces 11000-MY3-000)]
[95std&abs: 11000-MY3-020 / CRANKCASE SET]
[96-02std&abs: 11000-MAJ-G20 / CRANKCASE SET]
Apparently, you can no longer order the 91s' breather box or water pump. Just this week I learned that the 92-94 water pump is a suitable substitute.
Regards, John
