- Joined
- Feb 11, 2006
- Messages
- 9,685
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 008131
- STOC #
- 6651
Of course the first thought might be the V-4 configuration and that is true but that is not my point.
In the VFR1200X adventure bike the 1237cc motor has been re-tuned from the specification the sport tourer VFR1200F has. The F has about 150 hp at the rear wheel and while I do not have the torque figures at hand some of the criticism leveled at the VFR centers around how the 170 crankshaft hp bike feels weak under 5000 rpm. I rode one about 50 miles and I did not come away with that impression but rather felt if pulled at least as strongly down low as my ST1300 does and the ST isn't weak down there. Above 6000 rpm it was much stronger and I expected that as the ST1300 has about 110-115 rear wheel hp@7750 rpm and 82-84 ft/lbs of torque@6100 rpm. The torque curve on an ST1300 is very flat and boasts 70 ft/lbs of torque at 3000 with a gradual rise to the peak at 6100 rpm. It is a great road engine with lots of easily accessible poke and a silky delivery.
So what is the commonality? In the 1200X Honda softened the hp and reworked the torque curve to boost the low end so the bike has more grunt in the area where most riders ride. In this month's bike they published the power curves and they are almost identical to each other from off-idle to redline. The resemblance is uncanny. Both have 70 ft/lb at 3000 rpm and a gradual rise from there. The test 1200X peaked on the dyno at 109.7 hp at 7800 and 81.1 ft/lbs at 6600. Compare that to the averages of several published ST1300 dyno tests of 109.2 hp@7750 and 82.9 fl/lbs@6100.
I think the ST1300 engine is so under-stressed it could last nearly forever and the torque curve is perfectly suited for fast touring work that many of us do.
