Got a good buy on the new honda heated grips set. This is listed for model years partial 2010 and full 2012. I have not decided to install these yet as they will conflict with my Breakaway cruise control and I would have to get a throtlemeiser or something to that effect.
I will list some differences you should know:
1. These grips are 4 3/4 long , 1/4" shorter than the stock grips at 5" on all model st1300s up to midyear 2010. Somewhere in 2010 they shortened the grips and bars I can only surmise to fit these grips. They will fit previous years but will be sort of the bar ends so you would have to make up a spacer if this gap offends you. Looks like honda uses the same grip set for a couple of bikes then you order the specific hookup kit for your bike.
2. They are 1 1/4 in diameter the same size as the stock grips. They have a nice soft rubber feel just like the stock grips.
3. They kit is nicely done with clear instructions on how to install. It plugs nicely into the quartet harness (not included). The control modul fits behind the instrument cluster so the upper cowl cover must be removed
and the left side cover to access the quartet harness.
4. On the left grip there is a lighted push button that controls the three levels. Flashing each time to indicate where you are at. With a low voltage cut off. Right grip includes the throttle cable hookup so you do not have to slip it over the existing throttle tube.
5. The grips are wired up in series.
