Hopped on the 94 ST1100 for an errand, all normal until pulling to a stop 600 yards down the road.
The clutch lever, which I have always pulled to the handlebar, suddenly wouldn't not close the last 3/4". I was able to complete the next 6 or so shifts to get home, and while initially the clutch was just disengaged enough for 3 - 4 shifts (all first, neutral, second stuff), the last couple shifts were really difficult. Probably last in-gear test in the driveway, the bike may have moved slightly in first, with clutch lever as far in as possible, as one might expect.
Thus, the clutch itself seems to be operating fine; problem is that pushrod or somesuch just won't go far enough into the master cylinder. If I use a little strength pulling the lever in, there is a click and the lever comes in perhaps 3/16".
This lever has been a bit sloppy/loose in vertical movement for a while; I've read here on the blog about re-placing the pushrod, boot, bushing, and lever, but I don't feel too certain that others' problems had this characteristic of a clutch lever that wouldn't quite come to the handlebar, and generated a click if pulled a bit harder.
Anybody?
And, while we're at it, how do you get the bushing out of the clutch lever in order to replace it and the pushrod?
Thx a million
Anybody?
Thx a million
