Okay, I bought my [new to me] 2003 ST three weeks ago. After riding for a few days, I thought, "idling too high" (1500 rpms).
So, I grab a screwdriver and drag it back to ~1100rpm.
Erratic idle ... a time or two she dies when left to idle. Pulling away from a stop, it hesitates badly (is that a word?).
Note to self: "No wonder they set it to 1500rpm".
So the other night, I pull the plugs - gorgeous color! (though there's this weird 'drop of oil' on the portion of each plug 'above' the threads - I chalk it up to anti-seize being used).
Okay, plugs are fine.
Last night, I lift the tank to check the air filter. "Looks new" i think to myself. However, as I look at the bottom-side of the tank, i see the tab-retainer (which would retain one or more vacuum hoses and such) empty and I see a couple of hoses from the tank 'on their own'. Looking at an ST1300 microfiche, i see the 'drain tube' and 'breather tube' are the two hoses I [then] secured into the tab-retainer. After replacing the 'looks like new' air filter and securing the top of the air-box, I finagle the tank back into its position and tighten down the 2 retaining bolts.
A couple of hours later, I fire her up to go the the grocery store (and fill her up, as i have Kroger 10c\gallon discount) and notice that, suddenly, she's purring at idle and there is *no* hesitation pulling away from a stop.
(I researched 'erratic idle' and hesitation issues ... i've read there are vacuum lines around the throttle-body area that will affect this, but i did not see any vacuum lines with the tank lifted).
Question to the group:
Is there a vacuum line that was pinched which became "un-pinched" as a result of my raising and lowering of the tank, which would have improved low-rpm running?
