Ugh. 2 steps forward and 4 steps back. It seems I'm fighting one thing or another.
Quick Recent History:
* Picked up bike, great mileage (40+) for a while
* Pulled plugs (stock per manual) - look great !
* Weeks and weeks later, mileage dropping, got worse over time.
* Checked air filter, four-way vacuum ... all other hose connections
* Reset the CPU (jumpered plug under seat) recently
* Changed the oil (Shell Rotella T Diesel + filter)
* Mileage improved dramatically ! (from ~200 miles a tank to most recent almost 300).
* Last 2 days, performance going downhill fast - most recent tank fill - almost 70 miles and about 1/2 tank now.
* Removed plugs last night - look great ! (37,000 miles now)
* After re-installing plugs, fired bike up and took timing light pickup to each spark plug wire - light output (though right-rear cylinder seemed "not as strong").
If I'm sitting at a red light, and take off as you should, she coughs and spits ... if I bring the R's to about 2,000, and pull away slowly, she's fine.
I've heard her back-fire 2-3 times in the course of the last couple of days.
I run name-brand fuel,
I smell un-burned fuel out the back, even though timing light shows firing (borked plug?)
I plan to sync the throttle bodies this weekend - not sure that's it
Bad \ faulty injector?
Bad sensor?
Okay, here's the video to put this into some perspective (the "loud noise" you hear before startup is the radiator fan - sorry):
Notice when i blip the throttle, the idle bumps up too (that's not me holding the idle up).
Watch out for the spider !!
[video=youtube_share;P0CuoT8W3Dg]http://youtu.be/P0CuoT8W3Dg[/video]
Bad sensor?
