I'm thinking about these risers. But my 1100 ('02) has a plastic cover over the steering. Won't that interfere?
That's steenkin' plastic covers . . . and those 3.5" Rox risers will also require you to get longer hydraulic lines, so if you don't want that hassle, keep it to 2" risers.Plastic covers? We don't need no STinking plastic covers...
do you have the part number of that steering stem nut? That looks great!That's steenkin' plastic covers . . . and those 3.5" Rox risers will also require you to get longer hydraulic lines, so if you don't want that hassle, keep it to 2" risers.
This is what you do to make the plastic-less area look nicer.
A-ha! Duh.Yes. Leave the cover off.
Interesting. That looks great. Maybe the 2" risers will be better. Question: It looks like these simply clamp over the cylinders of the risers and the handlebars. I don't see any notches on them. I think that means they're almost completely adjustable as to final height, angle, etc. I could angle the riser forward, and then decide the angle of the bars to control the final distance. Is that true? Or are the angles involves pretty much pre-defined? Could it be that the fuel tank and fairing pretty much limit the possibilities?... those 3.5" Rox risers will also require you to get longer hydraulic lines, so if you don't want that hassle, keep it to 2" risers....This is what you do to make the plastic-less area look nicer.
Hmm. I'm curious why you chose HeliBars if you already had these on your bike. What didn't you like about them?I tried a 3" set on my '01. A reroute. Of brake and clutch as well as wires worked okay.
After a few rides, I opted for Heli Bars.
Yes, the part number is . . . Amsoil oil bottle lid in Black . . . stuck in place quite securely with a wad of Dum Dum.do you have the part number of that steering stem nut? That looks great!
You can adjust both the risers and the bars within the risers to suit, but ensuring zero contact with the windshield and top shelter (tank cover). There are no notches, but I mounted mine to come straight up towards me with the bar ends at their normal angle so that my hands lay flat (about parallel to the ground) when using the levers, if you know what I mean. Those that use 3" or more risers, like Irish, appear to be rotating their controls and master cylinders towards the front of the bike somewhat and that would help with the hose length problems.Interesting. That looks great. Maybe the 2" risers will be better. Question: It looks like these simply clamp over the cylinders of the risers and the handlebars. I don't see any notches on them. I think that means they're almost completely adjustable as to final height, angle, etc. I could angle the riser forward, and then decide the angle of the bars to control the final distance. Is that true? Or are the angles involves pretty much pre-defined? Could it be that the fuel tank and fairing pretty much limit the possibilities?
Awesome!Yes, the part number is . . . Amsoil oil bottle lid in Black . . . stuck in place quite securely with a wad of Dum Dum.
That's fantastic! I'd want to keep the plastic if at all possible, mainly because the previous owner installed heated grips with the hi/off/lo button embedded in that part. Using the hanger strap metal as an extension should work well. The key extension is interesting.I liked the plastic cover and wanted to keep it so I ....
The st1100 didn't come with any power outlets so it depends on who installed it as to whether it will be hot all the time or switched. I have 4 outlets on my bike that I installed. 3 are switched and 1 is hot all the time. The only reason I wired the one to be hot was so I could use that outlet to hook up my battery tender to instead of having a charger pigtail hanging off the battery.Well the 3.5" Rox extensions have helped a lot. I can sit upright when I want to and keep both hands on the bars. I left the plastic off and it's fine. I even removed the heated hand-grips. I don't ride much in winter. I didn't like the wires all over. Plus, whoever installed the heated grips took the power line off the outlet! So now it will be easy (easier) to reconnect that power.
I had to buy a longer brake line, but the clutch and all electricals were okay simply by re-routing them.
By the way, regarding the power outlet, does that normally provide juice with the key in the off position? It might be nice to make that switched.
