That hose he speaks of is fairly inexpensive from Honda , might want to replace it for a 2008 anyway - note : the hose ends are 2 different sizes with a molded-in bend . You can disconnect vent hose from upper tank nipple and drain the upper tank through the lower tank.Its tucked away under the pillion seat right in front of the rear indicator lights. Might even be a rubber strap holding it down. The rod with two bent ends running fore and aft on the left side of the bike (also under the pillion seat) is the tank prop for holding it up when playing around up front. You don't want to pull the tank up much farther than the prop would hold it. If you do yank it skyward, the big hose connecting upper and lower gas tanks might rupture or pull loose. Don't play w/ the tank while you are smoking.
Thanks for the replies.Its tucked away under the pillion seat right in front of the rear indicator lights. Might even be a rubber strap holding it down. The rod with two bent ends running fore and aft on the left side of the bike (also under the pillion seat) is the tank prop for holding it up when playing around up front. You don't want to pull the tank up much farther than the prop would hold it. If you do yank it skyward, the big hose connecting upper and lower gas tanks might rupture or pull loose. Don't play w/ the tank while you are smoking.
Hold off, don't replace that hose until you know that the 2008 and after, both ends are the same size on that hose....Unless you put a 2004 Tank on a 2010...But who would do that?That hose he speaks of is fairly inexpensive from Honda , might want to replace it for a 2008 anyway - note : the hose ends are 2 different sizes with a molded-in bend . You can disconnect vent hose from upper tank nipple and drain the upper tank through the lower tank.
sure thing.....I think the hoses are in good shape but I'll check if they are still attached properly.Hold off, don't replace that hose until you know that the 2008 and after, both ends are the same size on that hose....Unless you put a 2004 Tank on a 2010...But who would do that?
I did think about adding a decent set of tools to the bike,especially if I'm going on a long trip.I just wanted to see what tools the bike already has.Here is what the tool kit consists of- see here. It was shipped from the factory with the bike. Whether the original owner ever received it or not is another story. There is a debate about whether Honda supplies a tool kit or not. I have received it with every ST that I have bought regardless of year. I believe that Honda supplies it but the problem is that while it is shipped with the bike it is not installed on the bike. When doing the prep the dealers don't put it on the bike just as they often do not leave the knee pads in the saddlebag either as they are supposed to. I have mentioned this to several people (some in the U.S. as well as in Canada) who had bought new ST's. When they went back and asked the dealer they had the tool kit and the knee pads as well. Having said all that you would be better off to put your own tool kit together. You will have better quality tools and your kit will consist of the tools that you want to carry.
YEA- A Lot of ways to stock a tool kit for the 1300. This one just worked for me. Good Luck.You peaked my curiosity- If someone has decided that they want to purchase the Honda tools and they have an ST1300 why wouldn't they order the ST1300 tool kit?
Because the 1100 kit has more tools. The 1300 kits are just a few low quality tools.You peaked my curiosity- If someone has decided that they want to purchase the Honda tools and they have an ST1300 why wouldn't they order the ST1300 tool kit?
More's not necessarily better. If the 1300 has fewer types of fasteners, the extra tools would just be additional weight.Because the 1100 kit has more tools.
I have the tool kits from both models. They do have different tools in them but the difference in quantity is only one tool. As far as quality goes you are quite right that they are pretty low in that department. However, the 1100 kit is no better in quality than the 1300 kit so if I were the OP and I was missing the tool kit I would probably make up my own because of this.Because the 1100 kit has more tools. The 1300 kits are just a few low quality tools.
