God, the post is huge!I wonder if this is in a similar location and possibly the same job ?
https://www.st-owners.com/forums/showthread.php?155031-ST1300-Clutch-Slave-Cylinder-Replacement&highlight=
Thanks Pete. At least one good news today. While trying to find coolant leak I found there is a gas leak and clutch slave cylinder leak. I call it very successful day.... but at least on an ST1100 it isn't too hard to get at. The parts aren't that expensive
True. That's why I invested in December almost $1,000 in new final drive & new Michelin RP3.Yeah, a bit of bummer, but look at it this way: if you fix these things, it will likely be for the last time and also, you'll have been all over the bike so when you are done, you should have a great ride that will be safe and reliable for a long time at a tiny fraction of the cost of a comparable bike, bought new.
Well, there ya go - nearly done for now then.True. That's why I invested in December almost $1,000 in new final drive & new Michelin RP3.
While you're at it, might I recommend a rebuild of your clutch master, if it hasn't already. At least open it up and clean the gunk out of the master bore. There's junk in there that can block ports which cause the cylinder to build pressure. My brother-in-law had that happen on his brake master and it caused him to have to pull over and bleed fuild in order for the wheel to move. Once we figured out the problem opening up the master and cleaning it out fixed the issue and new seals didn't hurt either.
Your red arrow indicates the point where the hydraulic line attaches, with the banjo fitting. It needs two copper bushings. Your original bolt should be fine.Last night I took off the clutch slave cylinder - and it was nasty!
I cleaned it, and looks ok and still in good condition except rubber parts. So, I'm ordering the parts and (11 and 16) but on the fiche there is no part that I had in the service manual I looked at last night (and the book is still in the shoppe ). It's a screw with two rubber (?) rings I wanted to replace too. I checked on several different websites (online stores) but none of them have it.
Anybody knows what am I talking about and what's the item numbers?
Yes, exactly. Thanks. Now, where (on fiche) I can find the item numbers for the copper bushings? Or Menards/Home Depot are good enough?Your red arrow indicates the point where the hydraulic line attaches, with the banjo fitting. It needs two copper bushings. Your original bolt should be fine.
I think it's not #18, that looks different, and not the place I was talking about. And when looked the part # on ronayers.com there is no ST on the list?!?The copper washers should never be re-used. The parts illustration shows them as #18 part no. 90545-300-000. There are two washers needed at each end of the hose. It's the same part number for the washers used on the front and rear brake hoses connecting the master cylinder and caliper(s). There's a total of 14 of these washers on the bike. I always keep extras on hand.
You may want to disassemble the clutch master cylinder and clean it up if not replace the piston set while you're at it. Good Luck with your project.
