Where to put this???
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
Found this on the lift and have no idea where it put it. Round washer with a rubber over the center. There is only one, the other 2 are from my box of spares.
000540
also looks like the ones that go on the front of the tank where you screw to the frame.
Tacoma, Wa
They look like the rubbers that go under the bolts that hold the forward cowl to the engine guard
The Dan
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
000540
The tip over covers - once removed... that cowl has one like this attaching it to the frame/tip over bar...
2007 Honda ST1300A
Were you near the smog canister? (33706-KW7-900) or the lower fuel tank (50159-KR3-300) (61104-428-000) or as Mellow pointed out the grommet under the tip over cover (90501-124-000)?
Its hard to tell from the depth of your picture how deep the grommet is, perhaps you could take the two pieces apart to give us a better view?
It could be the front fuel tank grommet, after it has been crushed or over tightened, or as said, the top left radiator grommet and washer, or one of the two lower radiator mounting points.
Let us know what you find.
Deer Park, WA
Hopefully it is not like the problem I had were it was from a previous time it was apart and someone dropped the part in around the engine and when I was working on the bike it got knocked out of its hiding place.
000540
So now you have 3 of those...... how many ST1300's have you had?
