st1100 fuel gauge fault
maltby,s yorks uk
st 1100
Hi all just bought this bike yesterday and not had chance to get a repair manual as of yet and the fuel gauge is showing a full tank but there,s maybe a couple of gallon in at most,probably needs the sender cleaning but i would,nt know were to look for it, any info would be great,also what sort of mileage would be expected from a tank of gas 2 up with luggage,thanks
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
The range for this bike is between 400km-500km (250miles-300miles) the gauge will indicate full for close to 150km or 100 miles then drop fast. The sender is located in the lower part of the tank. So the float stays up till the first couple of gallons are consumed. The tank holds 28 litres of fuel
maltby,s yorks uk
st 1100
Thanks mate for the swift reply
Fort Worth, Texas
91 ST1100/06 ST1300
My 1991 reads max until after 120 miles or so. The indicator will not drop when you turn the bike off, fyi. If you need to service the sending unit, it is mounted to the left side of the tank, low down. You would need to drain/remove the tank....not difficult, just a little time consuming. Don't reuse the old seal.
West Michigan
'98 ST1100
8470
Be careful to disconnect the sending unit connector before you remove the tank. It's on the left side of the tank.
maltby,s yorks uk
st 1100
Thanks mate for that info,just been and pushed the float down with a long screwdriver and lo and behold the gauge dropped:)
N.C.
I had to remove the fuel tank when I repaired a coolant leak at the rear of the engine and everything worked fine afterwards but a few weeks later the fuel gauge started to play up ———-like dropping to empty and then slowly creeping back up to show there was fuel in the tank but has now stopped working completely.
I am at this moment trying to remove the gauge cluster as I suspected the gauge and it REALLY is a godawful job but then started to think it could be elsewhere——-is there any way of finding out where the fault lies?
I would be ticked off if I replace the gauge only to find the fault is in the fuel tank.
Is it the side sensor that shows the amount of fuel in the tank or the top one?
Thanks.
Graham Watson
British Columbia
2021 RE Meteor 350
This is one case where the Clymer manual is better than the Honda Service Manual, as it describes the test for that sending unit. Page 269, if you have one.
British Columbia
2021 RE Meteor 350
Couple of phone pics of the pages. The Table 3 referred to says Fuel unit resistance at full level is 10 ohms - at empty should read 90 ohms. Hope that helps.
N.C.
Bush,
Thanks very much for the info.
As I don’t know my Ohms from my Amps, I’ll go and see my Electrician Wizard and let him sort it for me using the info you sent.
Again, thanks very much for your help.
Regards,
Graham Watson
