misfire from cold that goes once warmed up
cambridge united kingdom
pan european st1300
Hi guys i'm getting some misfiring from my ST1300 2002 31k on clock pan when i start it up from cold
once warmed up it stops misfiring and runs fine
anyone come across this before
Gary.
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Edit:
(I read st1100 initially, oops my bad).
The only time I've seen an issue with a cold ST1300 is with a vacuum leak...
When it does this does holding the tach at or above 4000 rpm trigger an FI light? If so it will store a diagnostic code to check.
pan european st1300
will try the 4000 rpm when i start her from work tonight
not seen any lights come on
i am suspecting as Mark suggests this bike did 200 miles in 12 months spent most of it's last year in a garage with cloth over it.
possibly a cracked perished breather pipe.
i am waiting to move house once moved end of this week i plan to remove all tupper ware and see if i can see whats going on underneath
plan to put thermostat in her and new fan switch so may as well check everything while im in there.
and i think i oil and filter her while apart...
000540
Could just be some bad gas... I'd try some sea foam or whatever you chaps have handy over there that's similar.
when was the last time you cleaned the 5-way tee?
1&2&3-2005 ST1300ABS
001862
8562
Have you been using the bike regularly or has it been sitting in hibernation over the winter. My bike stubbles a bit for the first few starts if I leave it down for a month or 2.
After that, it runs fine.
