When my 92 ST1100 had about 20k miles on it, the coolant in the overflow tank began disappearing. Maybe twice a year it ran dry and I refilled it. There was no hole in the tank and the clear hose from the tank to the radiator was intact. I asked my riding buddies to look for white smoke coming out the tailpipe, but they didnt see any. I did get a wiff of coolant from time to time, but never saw any leaks on the ground or on the inside of the fairing pieces when I removed them for maintenance. Not a drop.
I just figured it was one of those things but kept an eye out for leaks, white smoke etc.
Then one winter I added a manual switch so I could turn on the cooling fan at will. Riding in 90 degree plus weather on the open road, the coolant gauge would always read about 1/3 of the way to redline. Get in stop and go traffic, and the needle would go to about 2/3 of the way. Sometimes 3/4. But it never overheated. At least according to the gauge! After adding the switch whenever I got into town on a hot day I would turn on the fan before the needle started climbing. After a little experimenting I found that running the fan for two or three minutes kept the needle in place. Then you could shut the fan off and the thermostat or whatever would keep the needle in the same place as riding the open road no matter how hot it got.
I never had to add coolant to the overflow tank again after that! Never caught a wiff of it again either!
But I never figured out why. Any ideas?
