Hello again .
Well , I got around to doing a compression test this evening. A bit of bad news on that front. Compression readings as follows,
cyclinder no. 1 , 150psi.
Cycl no. 2, 175psi.
Cycl no. 3, 185psi.
Cycl no. 4 180psi.
So ,I have a problem with cyclinder no. 1.
I did the teaspoon full of oil test which resulted in the compression jumping up to 200psi.
I think this means the valves are ok. That leaves piston rings and head gasket.
I must get my hands on a leak down tester to determine exactly where the compression is being lost.
As regards the snap crack at a very hot restart. I have put that down to pre ignition. Unless this lack of compression in one cyclinder is a factor.
Cycl no. 2, 175psi.
Cycl no. 3, 185psi.
Cycl no. 4 180psi.
