Dangling Tubes
jfheilman
South Carolina
2007 ST1300A
I have these rubber hoses/tubes that are dangling way below the bottom my ST1300 frame. They were not that way when I originally got the bike and I want to fie them.
Any hints on what I need to look for or things I need to not do?
Those are simply overflow tubes...If you look underneath the bike, you will see a metal loop type fitting that is attached to the corner of the pan by a single bolt. The hoses just slipped out of the fitting. Place them back in it, then you can hold both of them together with a small nylon tie at the end, this will prevent them from slipping out again. Just don't pinch them shut.
