I'd been looking for a good setup to get power into my top box for accessory charging. When travelling, I like to keep my camcorder, cell phone and digital camera charged up. Powerlet had the perfect setup. About half way down the web page it shows the setup for the ST1300. It is on order and should be a quick install.
http://www.powerletproducts.com/products/ptb.php#
I'll follow up once it's installed.
Pat
On a brighter note, my connectors arrived today and I just finished the install.
Placed masking tape over the outside and used the backing plate as a template.
Using a Dremel, I routed out the connector hole.
Test fit. I continued routing until the connector fit flush against the top box.
Drilled screw holes. I put the screw holes at 12, 3, 6 and 9 to avoid recessed area inside box.
Using a cutting wheel, I notched the backing plate to fit flush against the inside. I also had to remove the tab to allow for a flush fit.
Shows mount from inside. I added some black silicone sealant around connector to prevent any water leakage.
Shows finished inside connection.
Shows finished outside connection.
Overall, I'm pretty pleased with the installation.
Pat
