Wondering if any of you have had this problem before. I would fill up the tank, and get upto 190-199 miles, and then run out of gas. The gauge will still be around half, but the bike would not start. When I looked in the gas tank, I could still see gas, but the bike would not start. Then, if I put more gas in, the bike would start.
Went to my friend's place (he has a '98 st1100), and we took the fuel assembly out and noticed that the rubber hose for the gas inlet to the fuel pump was disconnected. So basically, when the gas level would go below the level of the rubber hose (when diconnected), the bike would stall. We put the hose back on the metal pipe in the gas tank, and so far the bike runs fine. I am down to 250 miles, and still no gas light. For my peace of mind, I put a metal clamp on the hose on top of the metal pipe.
Any thoughts? Is there supposed to be a clamp of some sort on the rubber hose that may have fell off? Any foreseable problems with me putting a metal clamp (screw-tight type) on the rubber hose? Thanks!
