jeff4912
'03 Honda ST1300 Std
Just did my valve clearance check and brake/clutch fluid change etc..
All my clearances were spot on except Cylinder #1 intake which was at .005 instead of .006
I was happy until I pinched the left side gasket and oil sprayed everywhere. Good idea to start the ST up before you put the tupperware back on to make sure its all tight.
Took the cover off and re-seated it and all was well. I re-used the original gaskets.
