You forgot "Credit Card with large (empty) credit limit"...
Mark
I'm leaning toward Mark's view: HRCA and Credit Cards can fix a plethora of ills. OTOH, how much time do ya wanna waste? On my August trip, I changed both rear and front tires (2 different stops) with next-to-no help in the time it would'a took the truck to get there. Not to mention that it was a holiday weekend and all the shops were closed anyway. I would'a got home Thursday 'stead'a Tuesday if I had made those phone calls. Maybe!
A few hand tools and a McGiver mind can go a long way toward keeping the wheels rolling. 2 weeks ago, after Leaving Don's place (with a freshly patched rear tire) I remembered what we had forgotten, to tighten the muffler mount bolt on the left side after fixing that tire. I stopped just _before_ the whoop-de-does in N.W. Nevada to check it. Of course, the bolt and nut were long gone (hope nobody following ate that bolt!
) Anyway, three plastic tie-wraps served fine 'til yesterday afternoon when I swung by my local True Value and picked up a replacement set.
Anyone else notice that the 8x1.5mm bolts at the hardware store all have 13mm heads 'stead'a 12? Oh, yeah, that's why I carry a 13mm box and socket.
In April, I lost a 12V pig-tail that fed my radio (vibration and dirt roads!) I managed to create a replacement (still in place as we speak) with a section of 16ga lamp cord and some crimp connectors from my store of spares.
On my way home (with fresh tires) on Labor Day weekend this year, I heard a _bad_ grinding noise in the front brakes when I coasted into a gas station in N.W. New Mexico. Ugh, worn front brake pads! I checked closely and found metal-to-metal on the left/front. About 10 minutes later I had usable (very used but pad material in place) pads installed. All it takes is the appropriate tools and _vast_ on the road experience.
2 years ago, I did a full caliper rebuild on both fronts in an abandoned gas station parking lot next door to a NAPA store in North (South?) Carolina. This took maybe 1.5 hours and a few bucks but sticky brake pistons are worse. I wasn't in any hurry, had many miles to travel, and good brakes feel better than hot/sticky ones.
Other tools? Multi-meter, a few feet of 14 and/or 16 ga wire, some crimp connectors, 12V soldering iron and solder, afore mentioned sticky plugs/tools and 12V compressor, assorted wrenches/sockets/ratchet/hex bits. Here's an electrical tip: big wire replace small wire just fine. Too much is better than too little. _And_ a double strand of too little acts exactly like the next size (2 16 = 1 14, etc.) I usually carry 16 ga. Keep in mind that it would take _4_ 16s = 1 12ga.
Also, i carry front wheel bearings. I've changed'em on the road _3_ times in the last 4 years.
And tar arns.
With a pair of spare tires, all the above weighs a lot less than a pillion passenger.
YMMV,
